Question about The Watches
I've been trying for weeks to be able to collect the cherries I lost when the watch video wouldn't work. I lost well over 200 cherries and no one will give me an answer. Can you help me collect them?
Steinhausen tm-478 single watch winder how it worcks
Watch Winder Setting & Instructions for Executive Collection
Jared Tracy
posted this on March 30, 2012, 2:44 PM
  • inShare
  • There are four modes for our Executive Collection of Watch Winders (TM and SM series):
    Mode 1 (both switches with the O pressed in): rotates for 180 seconds on then 12 minutes off.
    Mode 2 (first switch with the O pressed in, second switch with the I pressed in): rotates 180 second on then 15 minutes off.
    Mode 3 (first switch with the I pressed in, second switch with the O pressed in): rotates 180 seconds on then 18 minutes off, then 180 seconds in the opposite direction.
    Mode 4 (both switches with the I pressed in): rotates 180 seconds on then 24 minutes off.
    For switching winding direction:
    I pressed in will wind clockwise
    II pressed in will wind counter clockwise
    Neither pressed in will turn the winder off
    *Please note that the CW and CCW settings do not apply when the winder is set to Mode 3 as this mode winds in both directions.
Apr 10, 2014 | Steinhausen TM-478 New Single Watch Winder...
Rolex 1992 replica , minute hand loose
Replica watches are all made in one Chinese town. The parts are pressed, not machined. They dont last long and cant be repaired.
Go online and buy another replica (the best ones are around $200!)
Jan 09, 2014 | Rolex Daytona 116520 Wrist Watch
Prc 200 needing battery replaced every week!!! i
Your watch is draining the charge on the battery. It is possible that you have a bad coil or circuit block that is causing the battery to die. An acceptable battery should last you at least 9 months to a year. You need to send your watch in to the manufacturer to have them fix the motor.
Oct 05, 2013 | Tissot Watches
I lost two pins from my watch. What should I do?
you can bring it on any watch service center they have spare that match your lost pins. i hope i had been helped you.
Sep 11, 2011 | Guess Gc Collection Diver Chic G36001L1...
My problem is I lost this watch, and I am trying to find the same exact watch
Go to http://www.crotonwatch.com/ and click on "collections" menu and choose "watches".
You will see all the watches that they make which may include the one you want.
Whem you find the watch you want, click on the picture and there will be details and "retailer search".
Oct 01, 2010 | Croton 23k Goldplated Steel Watch for...
I bought a digital watch for my grandson but we lost the instructions on how to set the time and alarms. it is a all sport night vision water resist 100
You can get instructions from their web site "boluva.com". Select your area and click on one of the pictures.
Find your watch in the collections and get some details These should include instructions
Feb 21, 2010 | Bulova Watch
Citizen Eco Drive second hand stoped working
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life. As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
May 31, 2009 | Citizen Eco-Drive BL5184-56L Wrist Watch
Okay, if you say your battery goes bad, did you store your watch in a drawer as many people do? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
Mar 05, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
13 people viewed this question
Top The Watches Experts
D. E. Hev
John mullen
vince
Are you a The Watch Expert? Answer questions, earn points and help others
