Question about Lands Phones
Handset 2 is not ringing on my bt8500 - Lands Phones
How to adjust ring time on Unidentifiable 6.0 DECT cordless phone
does the mani handset have a menu button . if yes press it then look for ring time setting might only have 3 options tho 2-4 or 6
Dec 09, 2017 | Dect Lands Phones
BT8500
Yes, there is a model BT8500.
Nov 07, 2014 | Lands Phones
Some 816 phones won't ring on incoming calls
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
Jun 05, 2010 | Samsung Prostar 816 Phone
Line 1 of the pro star 816 will only ring on one of our phones and not the other. Line 2 and 3 rings on the seperate phone but not the other one. How can I make all lines ring on both phones?
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
Jan 08, 2010 | Samsung Prostar 816 Phone
THE PHONES DO NOT RING
with the handset2.gif down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
Oct 01, 2009 | Samsung Prostar 816 Phone
Ge model 28213ee2-a 2nd handset doesnt ring when a call comes in
assuming all the settings are correct, and sometimes there's a tiny switch on the handset for ringer, that has to be on, try the 'page' feature [the button on the base to make the handset ring to find it] - if that doesn't work, there's a very good chance the ringer itself is bad. i've seen that many times.
May 26, 2009 | Uniden Cordless Phone
One handset doesnt ring
There should be a ringer tone and volume control on the second handset. Sometimes there is a ringer on/off switch on the side of the handset.
If that doesn't work, then there is a possibility that the speaker is broken.
Phone dont ring
press #when finished. hope that helps
Sep 04, 2008 | Samsung Prostar 824 Keyset Telephone
No ring on handset
It may have lost the link to the base unit. Make a note of all the personal details, stored number, etc., then reset the handset. Do this by pressing the spanner button until the display changes, then press and hold the 'R' (delete) button until the handset resets. You'll have to set it up again, but at least it will link.
Spanner then 1 for ringtone, CID for volume.
Spanner then 2 for keypad bleep, 1=off, 2=on.
both cases press spanner to confirm changes.
Jun 28, 2007 | NTL VS1500 Cordless Phone
Lands Phones Logo
56 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
