Question about Health & Beauty
Mobility scooter wheels running when i sit onit to go forward it struggles to move....please help..
Mobility scooter wont go forward..
gewiz
  • 1263 Answers
SOURCE: rover three wheel mobility scooter full charge
First of all,
Make sure the freewheel lever is unengaged (up or down ?) , this can be tested by pushing the scooter forward , you should hear gearbox clunk,(Freewheel not engaged) Not all scooters sound a alarm when freewheel is engaged.
is the power indicator working okay,
Does the Wig Wam move freely, the thumb throttle part,
Check under the seat to make sure you have not blown or tripped the fuse, if it's a switch simply pressing the button will sort it, if not check the two prong fuse ,
you may also have some reset buttons on the stem so look out for them.
Now let me what you tried
Regards
GeWiz.
Posted on Jul 24, 2009
SOURCE: Pride Rally 3 Wheeled Electric Mobility Scooter manual
DO not ask FIX IT ALL THEY WANT IS MONEY
Posted on Nov 25, 2009
SOURCE: Scooter won't move forward or backward
jdl0755, I'm having the same problem with my DKS-200. I was wondering if you determined the problem? I'll let you know if I figure it out with mine.
Posted on Dec 17, 2009
  • 61 Answers
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Posted on Mar 19, 2010
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
Power shuts off when i sit on the scooter
Hi, it's only a loose connection or bad connection, pinpointing it will be harder, now turn over the scooter and check the wiring connections
from the battery connector to the controller mounted under the floor board, the best way is to have the scooter running while you move varoius cables but be careful of the wheels etc you will need someont to help you, take care...
Regards
Rob
www.gewizrepairs.co.uk
Jan 02, 2014 | Shoprider Mobility Products, Inc. Hero...
When i go forward or reverse i get a click the scooter does not move
Please check near the rear to ensure the the scooter is in gear. There should be a switch that needs to be moved up/down. Let me know if this is not the issue.
Good Luck!
Apr 14, 2011 | Pride New Mobility Victory XL 4 Wheel...
1997 PRIDE VICTORY GIVEN TO ME, BUT NEEDED FRESH BATTERIES PURCHASED NEW BATTERIES INSTALLED THE KEY, LITES & HORN WORK BUT UNIT WILL NOT MOVE FORWARD AND/OR BACK
check the freewheel lever on th rear of the chair near the right rear wheel if you can push the scooter easily then you are in freewheel locate the lever and move it to the drive mode and try to drive the scooter again if it still won't move then you have other problems that can only be checked by a service tech Hope this helps
Feb 26, 2011 | Pride Mobility Products Pride Mobility...
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Scooter won,t move .sometimes moves erruatic
Hi. Sounds like the motor brushes need attention. If you push the scooter when it wont move, does it suddenly jump forward. If so then its definitly the motor brushes. Good luck. Neil.
Feb 14, 2010 | Elite Pride Go Go Traveller 3 Wheel
Rover three wheel mobility scooter full charge horn working but just wont move
First of all,
Regards
GeWiz.
Jul 20, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
