Question about Water Heaters
I can't pressurise my worcester boiler. I have tried putting the key in and turning the tap many times but it won't re-fill. What am I doing wrong?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Did you provide a way for the air to escape in order to allow room for the water?
Posted on May 03, 2017
Testimonial: "No, I didnt know about having to do that."
  • Barry Hogarth
    Barry Hogarth May 03, 2017
    No, I didn't know about having to do that.
Worcester 30cdi boiler showing no pressure fires up and then cuts out
Re pressurise via filling loop,if boiler continues to loose pressure replace the expansion vessel.
Oct 16, 2017 | Water Heaters
Hi I have a 24i worcester boiler I have drained the heating to do some work but I need the hot water to still work.I spoke to Bosch and they said I need to put a loop in.I am not a plumber but can get
Hi Steve, I am not a plumber but have done a lot of DIY on my own heating system with Worcester Bosch combi boiler! I believe that you can have the hot water on without the heating system filled, just turn all the settings as for summer use and the thermostat right down so the heating is forced to stay off!
Nov 07, 2014 | Water Heaters
Worcester bosch 24i combi empties itself after re-pressurising Whilst re-pressurising boiler my partner (carelessly) went over the max pressure, it hissed & promptly emptied itself- I assume this...
3 psi is a little over the average, 2.5 is the optimum setting. If it empties itself, it means that the safety valve is working,which prevents any kind of damage to pipes etc...Make sure the valve is open and close at the right time and top up the system slowly rather than in a hurry. If the system requires regular top up then there must be a small leak somewhere, so it is best if you can fix that too. Remember that there are some solutions that are added to the water circulation and if you are constantly topping up with water then you are losing these solutions that prevents rust build up etc...Hope this helps.
Oct 28, 2010 | Bosch Water Heaters
The water pressure on my Greenstar 25Si Worcester Bosch combi boiler is so low that the shower won`t heat up. Can someone please tell me how to increaese the water pressure as there doesn`t seem to be an...
The boiler has a filling connection which uses a filling loop to connect the boiler to the mains supply for the initial fill and subsequent fills.
See the link below from the manual you can buy the filling loop connection online or ebay its a simple task to replenish the pressure. Worcester GREENSTAR 25Si Instruction Manual Filling The System
Feb 06, 2018 | Water Heaters
How do i refill ny worcester junior 24i combi boiler? as i cannot get the pilot light to light
Two types dependent on age
Early - in the mains water inlet pipe there should be a service valve/tap which when turned on will refill [it is close to or part of the fill loop - a metal braided flexible pipe
Later - underneath there is a hole for a plastic tap [supplied with boiler] to be inserted [usually just right of center] Insert and turn 90 degrees then close to it another small knob or 2nd tap which when turned [same action as a basin tap] will refill. If the first tap is not inserted properly water will drip out past its seals
For both Refill to about 1.5 - 2 bar and turn off
For the later as above but also remove the 1st tap
Mar 14, 2010 | Water Heaters
Low pressure on recently serviced Vokera 14/48se.
Identify the cold feed to the boiler, then look for a tap/service valve which when turned lets water into the boiler via a fill loop to pressurise it. 1-1.5 bar is ok
ju
Nov 05, 2009 | Water Heaters
Worcester greenstar hot water fluctuation
the limit stat could be out of calibration, low water rate, by/pass if fitted may need reculated, could be blocked heat exchanger best of luck
Mar 03, 2009 | Water Heaters
Water Heaters Logo
49 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
