Question about John Deere Garden
John Deere Z225 starting problem. The solonoid only clicks when I turn the key.I replaced the battery, the starter, the ignition switch and the starter solonoid!
    Sergeant:
  • 111 Answers
What about the starter relay?
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
Posted on May 03, 2017
  • 70 Answers
With everything you have done only 2 things come to mind.
1) Safety switch open or not functioning.
2) Engine seized.
Why does my LA105 john deere lawn tractor only click when i turn key?
The click you hear is the starter solenoid. If the starter doesn't engage, it is suspect.
Apr 01, 2015 | John Deere Garden
I need a sele oid wiring guide for a john deere z225.
25406829-sdtuz4uzlvmm4ye1kcvubb3h-5-2.jpg Basically the large wire from the battery goes to one of the larger threaded copper terminals and the large wire to the starter goes to the other [no particular order] The two small wires from the ignition and return via other interlock switches go to the two spade terminals [again, no particular order].
Feb 08, 2015 | John Deere 22 In. Rear Tire Chains
Un able to turn off z225 mower using key switch
You need to replace the key and key chamber as your one may be faulty
Jul 22, 2014 | John Deere Riding Lawn Mower. EZtrak Z225...
John Deere Z225 trouble starting - turning the key to start, you hear the starter engage. The engine trys to turn over but struggles. Sounds like the battery is low. Bought a new battery, charged it...
The symptoms described may indicate a bad starter. First check all connections from the battery to ground and from the battery to starter You may want to have the starter tested at Advance Auto or Auto Zone. It will need to be removed from the mower, and I am not sure if Auto Zone, Advance Auto can test small mower starters. They test the starter under load, so if you remove the starter and hook it up to a battery, it will run probably, but it will not indicate whether the starter is good or bad. It needs to be tested under load. Good luck.....
Mar 18, 2014 | John Deere EZtrak Z225 Zero-Turn Riding...
John Deere 855 Compact tractor has no power to solenoid
Power from the battery direct to a big terminal on the solonoid. The other big terminal leaves the solonoid for the starter. Then there are either one (1) or two (2) smaller terminals on the solonoid. If there is one then the body of the solonoid is the ground. With two of course the extra is the ground. Make sure the solonoid has a good ground.
Remove the smaller terminal from the solonoid ( usually yellow) and connect the positive end of a multimeter or a DC volts tester to it. ground the other end of the tester and turn the ignition key to start. If you get 12 volts to the wire end then the solonoid is bad and should be replaced. If no voltage is registered then the ignition switch is bad or an inline safety switch such as: nuetral, clutch/brake, PTO, seat ( Operator Presence Switch). Or you have a bad wire, bad ground, bad connection somewhere in the starting system.
Oct 31, 2012 | John Deere Garden
I can not get my John Deere 2020 to start. I have replace my battery, rebuilt the starter, and replaced the key switch. What else can I check?
the john deere 2020 gas tractor has a automatic reset breaker. If the tractor has a short it will shut off power to the ignition switch and reset in 60 sec. If the breaker is bad you will have power at the switch until you turn it to start or ecc.then no power at the ignition switch. I can not find the breaker. let me know if you do.
Sep 04, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Starting my 200 chevy venture
either replace ur ignition switch or replace ur starter solonoid
when u turn on ignition switch u should get a click fron a relay under dash listen for that and if u hear a click then u need to replace solonoid on starter or replace whole starter motor also clean and inspect battery cable good luck with this project
Jun 30, 2008 | 2000 Chevrolet Venture
Garden Logo
168 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
