Question about Optics
I need a stock for a Harrington Richardson model 865 rifle .22 cal. any help finding one?
SOURCE: Reassembly of Air Rifle
Go to www.airgundevelopment.com and scroll down to the link that says crossman valve. I used these pictures to get mine back together. It's not an exact science, but it sure does help.
Posted on Mar 05, 2009
SOURCE: winchester model 100 semi-auto 308 cal. how to disassemble?
IMPORTANT Recall info:
WINCHESTER MODEL 100 FIRING PIN RECALL - A notice dated 7-1990 relates the following
“PRODUCT SAFETY WARNING AND REPLACEMENT NOTICE. Attention owners of Winchester model 100
rifles and carbines please read this notice. In July of 1990 the following product safety
warning was issued by Winchester. It has come to our attention that the firing pin in the
Winchester Model 100 Rifle or Carbine may break due to use and metal fatigue and become
lodged in the breech bolt face. If this occurs, the firearm may fire before the action is
locked causing severe damage to the firearm and possibly injury or death to the shooter
and bystander.
WARNING DO NOT SHOOT YOUR WINCHESTER MODEL 100 RIFLE OR CARBINE. Repair and replacement.
A new firing pin has been designed to replace the firing pin originally made for the
Winchester Model 100 Rifle and Carbine. The new firing pins will be available in April
1991. If you own a Winchester Model 100 Rifle or Carbine, please send your firearm to one
of the authorized Winchester Model 100 Firing Pin Replacement Centers indicated below.
Your Winchester Model 100 firearm will be inspected, the firing pin replaced and tested
and the firearm returned to you. The inspection, replacement/testing and return postage
will be accomplished at no cost to you. If other repair or maintenance work is authorized
by you to be performed on the firearm when the firing pin is replaced, such work shall be
at your cost.”
W. R. Long Gunsmiths
2007 Brook Road North
Cobourg, Ontario K9A4W4
Canada Frank LeFever & Sons
RD 2 Box 31
Lee Center, NY 13363
USA Bolsa Gunsmithing
7404 Bolsa Avenue
Westminister, CA 92683
USA Nu Line Guns
1053 Caulks Hill Road
Harvester, MO 63303
USA
If you have any questions concerning this notice, call Winchester Product Service
1-800-852-5734 or write to Winchester Firing Pin replacement Notice, PO Box 10 Cottage
Hills Illinois 62018 Attention Product Service Dept.
The following is Wisner's rendition & info on the subject.
The difference in the old firing pin and the new one is as follows. The old replaced
style, was totally lathe tuned (round). While the new recall style is similar in lathe
turning on the front and back, but in the front midsection it has two flats milled, one
on each side. This makes the center section stronger. Also replaced is the bolt sleeve
lock pin (firing pin guide) which was made to accommodate this different shaped firing
pin
Part number for the new parts are, firing pin =1391ND, bolt sleeve locking pin =1491ND
The word was at the time this recall was in process was that if the firing pin would
break at the mid section and still remain in the gun as two pieces, the possibility of a
premature discharge before the bolt was locked was possible. This apparently was caused
by the firing pin tip (now not having a retracting spring) to be stuck forward, and
thereby slam-firing upon chambering.
The responsibility for the recall apparently was on Olin, as they were the parent company
at time of manufacture. Olin set up regional recall centers at three established US
gunshops. There was a manufacturing delay in the replacement firing pins, and a backlog
occurred, also some collectors did not like the idea of shipping their guns long
distances. Olin then also authorized other gunshops to make the required alterations.
Upon completion of the recall, the shops were to test fire the firearm and to stamp an
assigned letter on the inside top of the receiver as seen thru the magazine well with the
bolt retracted. The letter “B” represented Bolsa Gunsmithing, “L” was Lefever, and “N”
was for Nu-line Guns. The letter “X” apparently was for all the other independent shops.
However this identification information did not get communicated to some of the smaller
shops at the start of the project. The only way to tell if the gun as been modified, if
the ”letter” is not present, is to take the barrel & action out of the stock, remove the
trigger guard assembly and the try to rotate the firing pin by twisting it. If it does
NOT rotate, then the firing pin recall HAS been performed.
For link back to the parts & price list that we make & have for sale CLICK HERE
Copyright © 2004-2007 Wisner's Inc. All Rights Reserved
Back to Additional information To Winchester model 88 & 100 parts
Originated 01-13-2001 Last Modified 03-19-2007
LeeRoy Wisner
Posted on May 20, 2009
  • 5 Answers
SOURCE: my model 88 Harrington and Richardson 12 gauge
You first need to **** the gun then remove the fore end and barrel and look at the breech face when pulling trigger , you will see if firing pin is there. If not u need a new pin as it is probably broken. Take it to gunsmith if u are not familiar with the workings and get a new pin .
Posted on Oct 27, 2009
cuvilldj
  • 14 Answers
SOURCE: where is the serial number located on a remington
693f0fe.jpg Introduction Year: 1936 Year Discontinued: 1955 Total Production: Approximately: 12,200 Designer/Inventor: C.C. Loomis, A.L. Lowe, K.J. Lowe Action Type: Bolt Action – Clip Magazine Caliber/Gauge: .22 Long Rifle Serial Number Blocks: Starting: 00001
Ending: 12300 Grades Offered: Model 37 Rangemaster
37 Target
37AR
37AF
37AX
37AM
37AV
37AS Variations: None
Posted on Dec 11, 2009
roadtech7
  • 297 Answers
SOURCE: I I bought a used
The easiest way is to get a boresighter, it will get you on the paper at 25 yards then the rest is up to you.
Hope this helps, Matt
Posted on Jan 01, 2011
Harrington richardson 243 modle sb2 ultra would like to know the value of this gun
H&R SB2 Ultra .223...whats it worth? ' The Firearms Forum
www.thefirearmsforum.com > ... > The Ask the Pros & What's It Worth? Forum
  1. Cached
  2. Similar
Apr 9, 2011 - 9 posts - ‎4 authors ... i can get for it. Its an H&R SB2 Ultra .223 with a Bushnell 6x-18x,50 Banner... ... NIB - this model in that caliber sells in the $279 - $290 range.
Harrington For Sale - GunBroker.com
www.gunbroker.com/Harrington-Firearms/Browse.aspx?Keywords=Harrington...
  1. Cached
  2. Similar
H&R Harrington & Richardson SB2 Ultra 243 win ... Harrington and Richardson Handi Rifle 243 Win ... H&R Model 158 30-30WIn -LIKE NEW-single shot.
Harrington Richardson Rifles For Sale on GunsAmerica
https://www.gunsamerica.com/Search.htm?C=325
  1. Cached
24 Listings - Beautiful H&R (marked Wesson & Richardson) Model 1871 Buffalo Classic ... Harrington & Richardson Handi Rifle; SB2; in .243; 22-inch barrel; adult ... Harrington richardson 243 modle sb2 ultra Google Search
Dec 02, 2016 | Harrington & Richardson H&R Superlight...
What is manufacturing date for Harrington& Richardson Revolver Model 922 .22 Caliber. Serial # K15297.
According to Goforth's book, Supershots with K serial number prefixes were the earlier 7 and 9 shot models, which did not have the Sealed 8's countersunk chambers.
K17250 - 17259 was made 1932
https://www.amazon.com/Bill-Goforth-1871-1986-First-Hardcover/dp/B00RWS4AKE
this is confusing
IF
E = 1944
F = 1945
M=1952
K - what year does it make a model 922 .22 cal
May 27, 2016 | Optics
I was told there was no such thing as Benjamin Franklin mod 312 Ser h322837 but is in enshrined on the barrel, I need to know
Definitely exists and looks collectible.
  • Benjamin Franklin 312 .22 ' Gun Values Board www.gunvaluesboard.com/benjamin-franklin-312-.22-2923214.html My father has a Benjamin Franklin , model 312 .22 cal. Lever pump rifle , ... A Benjamin 22cal air rifle with a ser ... .22 cal Mod. 312, ...
  • i have a benjamin franklin 312 air rifle with no serial ... https://answers.yahoo.com/question/index?qid=20110411133733AAHQmgM
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2011-04-11 · I have a benjamin franklin 312 air rifle with no serial numbers on ... What you have is a Benjamin model 312, ... I have a benjamin franklin 312 air ...
  • Advice on what to do with Benjamin 312? - Airguns & Guns ... www.gatewaytoairguns.org/GTA/index.php?topic=25607.0 Advice on what to do with Benjamin 312?, ... Benjamin Pump mod. 397 ... SE CT; Beeman C1 .177 Daisy 230 (Milbro)
  • Related searches for Benjamin Franklin mod 312 Ser h322837
  • I Have A Benjamin Franklin Model #312 - Lever Pump Air ... www.gunvaluesboard.com/i-have-a-benjamin-franklin-model-312...rifle... I have a Benjamin Franklin Model #312 - lever pump air rifle in .22 cal. The stock is broken & I would like to get it fixed. ... A Benjamin 22cal air rifle with a ser ...
  • Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle ... www.ebay.com/sch/sis.html?_nkw=Benjamin+Franklin+Brass+Mod+312+22... Find best value and selection for your Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle Gun For Parts search on ... Benjamin Franklin Air Rifle for parts . $ ...
  • Item:8679966 Benjamin Franklin 312 AIR RIFLE PARTS .22 For ... classic.gunauction.com/search/displayitem.cfm?itemnum=8679966 Seller's Description: Benjamin Franklin 312 AIR RIFLE PARTS .22 Nice old Benjamin 312 barrel, receiver and stock Pumps air okay but there is no way to release it as ...
  • benjamin franklin 312 - Airguns & Guns Forum www.gatewaytoairguns.org/GTA/index.php?topic=37115.0 benjamin franklin 312, Air guns, Airgun Forum ... 2 RWS mod. 48s, 177, & 22 2 Benjamin Marauders 22, & 25 Benjamin Trail NPXL1100 Benjamin Pump mod. 397, ...
  • Benjamin 312 strip, tear down & dis-assembly - YouTube www.youtube.com/watch?v=W1_DGNaaAs0
    • BY NORTHWESTAIRGUN
    • 17 MIN
    • 45K VIEWS
    2014-02-06 · Video embedded · Video of the dis-assembly of the Benjamin, or Benjamin Franklin, model 312. This is similar to the model 310, 317, 342, 347, and ...
  • Ben franklin air rifle mod 312 parts diagram - fnsxowf.gq fnsxowf.gq/zeuimpooku I have come across a Benjamin Franklin Mod.340 Cal.Buy Benjamin & Sheridan ... Benjamin Franklin 312 Pump air rifle.New airguns and vintage are available in our ...
  • Need A Repair Kit For A Benjamin Air Rifle Model 312 ' Gun ... www.gunvaluesboard.com/need-a-repair-kit-for-a-benjamin-air-rifle... need a repair kit for a benjamin air rifle model 312 ... I bought an old Benjamin air rifle model # 312. ... I have a Benjamin Franklin Model #312 ...
  • What is my Benjamin Franklin model 312 cal 22 h148881 man in USA
    May 20, 2016 | Optics
    I need a Harrington & Richardson Model 265 "Targeteer" .22 rifle magazine Clip. Where can I find one?
    Try Triple K Manufacturing, get the magazine for the Harrington & Richardson mod. 165. It is the same magazine as the mod. 265 Targeteer.
    Oct 20, 2014 | Optics
    When was my Harrington and Richardson Model 171 Cavalry Carbine manufactured, serial number SA2062?
    It's a Model of 1873 'Trapdoor'. LOW POWERED ammo ONLY. Do NOT shoot ammo designed for Marlin or Ruger.
    Oct 06, 2014 | Optics
    Harrington and richardson
    The Harrington & Richardson M4 survival rifle was made in the 1949 for the U.S.A.A.F. & U.S.A.F. It was meant as a survival tool for downed pilots and crews. 29,344 were produced. Depending on condition, they can range from $400 to $1,800. Also, be aware that the original military barrel length of 14 in. made this a short barreled rifle, which required a $200 tax stamp and paperwork from the BATFE. Most surplused to the civilian market were re-barreled to 16 in.
    Mar 05, 2014 | Harrington & Richardson Optics
    I have a Harrington @ Richardson Officers Model 1873 Springfiel and need to know if its possible to fit this rifle with a sight just forward of the chamber
    It's basically a reproduction of the Springfield "Trapdoor" rifle, so I's assume you could, just like the originals had.
    Dec 06, 2013 | Harrington & Richardson Optics
    I have a 243 cal single shot that snaped when fired. Tried different ammo. still misfires
    Firing pin is worn. It may make a slight dent in the primer, but not quite enough to press against the anvil inside of the primer, hence the misfiring
    Talk to a gunsmith to see if he has any spares, or has the ability to repair the firing pin.
    Oct 03, 2012 | Harrington & Richardson H&R Sportster in...
    Optics Logo
    35 people viewed this question
    Top Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    james laughton
    james laughton
    Are you an Optic Expert? Answer questions, earn points and help others
