Question about Dewalt Saws
Dewalt schroll saw repair, the machine stared vibrating and making a noise
  • 6 Answers
SOURCE: Vibrating noise
u may have food in pump u see sometimes it dose happen i have pop corn seeds in mine
Posted on Dec 16, 2008
  • 531 Answers
SOURCE: loud vibrating noise
may be screw left out
Posted on Apr 02, 2009
  • 80 Answers
SOURCE: hi, my dewalt 12 inch double bevel, is making a
This sounds like a problem with the electric brake on the motor.
Posted on Aug 30, 2009
  • 6 Answers
SOURCE: bad vibration and noise from saw
Are you sure blade is straight, and mounted on arbor correctly? that's the first thing to check. Or remove blade and 2 arbor plate's and run saw. If you have a vibration after that you have a bearing problem.( rear bearings go bad on these saw's) other they are the best saw for the price. We have about 50 of the 4000 model. hope that help's Never had a vib problem.
Posted on Jul 25, 2010
SOURCE: Dewalt DW788 scroll saw noise
hello,,,i just bought a new dw788
Posted on Aug 30, 2010
My newer dewalt d2400 tile saw was making a really bad noise than quit working. It sounded like a bearing was going out then no power at all. Any ideas where to start?
check brush length
m ost likely a burnt armature
take it in to an appliance repair shop for a proper diagnosis and quote
Nov 17, 2016 | Dewalt Saws
Is there a fix for heavy vibration
Sadly dewalts vibrate a lot! They don't have the counter balance the the Milwaukee and Makitas do. My guess is it's fine. I'd check the four screws that hold the gear case to the body regularly to make sure they stay tight.
Mar 02, 2014 | Dewalt DC385B 18v. Cordless Bare...
Power is going to the motor on my dewalt 12 mitre saw but the motor is not spinning
Does the saw make any noise? If not it could be an open circuit in the field coils
Feb 22, 2014 | Dewalt Heavy - Duty 12" Double - Bevel...
Severe vibration with Dewalt 744S Table Saw
try it with no blade
if you have unhabitual noise and vibration,probably need to change bearing
if you do not have a bearing puller do not try to do it yourself
professionals will take 2 to 3 times less time than you do the work and if there is something else damaged, (gear damaged,) he will see it and inform you
Sep 22, 2012 | Dewalt DW744S 10" Portable Table Saw with...
I've been using dewalt miter saw dw715 for several years and it's been working great. I just moved and today I used the saw in the new place, on an uneven concrete tiled ground. After several cuts, I...
This is common IF the blade clamping nut becomes loose... the blade will free wheel on the arbor after the motor stops. It can tear up the arbor so investigate this possibility immediately.
Feb 19, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Hi, my dewalt 12 inch double bevel, is making a
Aug 30, 2009 | Dewalt Heavy - Duty 12" Double - Bevel...
Jan 17, 2009 | Dewalt & Variable Scroll Saw
Vibrating noise
Dec 16, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dewalt Table Saw
I don't know about Cleveland, but a while ago I replaced the bearing on my Sears Craftsman saw, and it wasn't a hard fix. I would expect any competent repair shop could do the repair easily. If you can get the arbor off and take it to the shop, that would be ideal. It only takes loosening a few bolts to get it off. I first removed the cast iron top from the sheet metal base so I could turn it over, but it can be done from the bottom, too. Just be prepared to eat some sawdust. The most specialized thing the shop would need is a bearing press to get the bearing in and out of its seat, and many shops would have these; they aren't very expensive. Maybe a good machine shop which does small jobs could do it for a small fee. A good place to find these is at your local auto parts store, such as NAPA or O'Riellys (here in MIssouri, anyway, but you get the idea). Your auto repair shop probably knows one or two they use for 'turning' brake drums, etc. BTY, I didn't have a bearing press and I did the job with carefully tapping the bearing back on with a sleeve made from a piece of scrap pipe. Tauton Press makes a great DVD on tuning up your saw after this fix, as you want to make sure
it is square with the table in two dimensions - parallel to the miter saw slots and perpendicular to the top. Good luck.
dcm
Sep 12, 2008 | Dewalt Saws
Saws Logo
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
