Question about The Office Equipment & Supplies
My riso EZ 390U wont let me open the master making unit. the green light comes on when I push the release button but it doesn't stay lit and the door won't release
SOURCE: Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Posted on Dec 06, 2007
  • 247 Answers
SOURCE: OLDER SEARS GARAGE DOOR OPENER WONT OPEN GREEN LIGHT FLASHING
do you have the sensors at the bottom of the door? if so they might be out of alignment. all you have to do line them up by getting the green light solid. let me know if this helps you.
Posted on Dec 18, 2008
  • 139 Answers
SOURCE: pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Posted on Jun 25, 2009
lemmingleejn
  • 173 Answers
SOURCE: Lift-Master garage door opener stopped working
The motor will probably need rewinding.
Professional job. Don't forget to take the condensor with the motor.
Or alternatively, if money isn't a problem,, get somebody out to look at it.
There ya go:)
Posted on Jul 27, 2009
SOURCE: sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Posted on May 13, 2010
How can the master roll be opened without the use of the release button?
by using & insert a pencil or 4mm screw driver , press manually master unit release switch on master unit cover ( small hole ) on bottom side of master unit cover and draw master unit by other hand
Mar 02, 2015 | Riso RZ220 MASTER UNIT - ONE ROLL PACK
How to replace master in a riso
open the door. on your right side there is a button for release of the master holder. press it. when it unlocks the lock, pull it out. open the press of the master. there is a lever for release of the master roll. remove the RF module the black colored cap on the left end. get the master roll and follow the instructions printed on the cover of the master presser. close it and you are good to go.
Jan 18, 2014 | Riso RZ220 Duplicator
Riso EZ 200E model gives error message A-01 -211
A-01-211 basically means there is master material under the position sensor while in standby. Referring to the manual open the master drawer and clamp rewind the master material back on it roll and close the lid/clamp. This allows the master unit to reset or to say "return home" action. Now open and re-insert the master material in its proper place. This is similar to A-34-218 code.
Nov 07, 2013 | Riso RZ220 Duplicator
Riso RZ 220 UI The master drum will not come out and the green light is not on.
This is for master drawer not responding to green light to be released question. Try turning ON machine (turn off first) while holding down the reset button. Also a mechanical way is a small hole to insert a pencil, eraser end first, just below green latch area. Just insert hold in while squeezing release latch. to drawer.
Sep 09, 2013 | Riso RZ390 Duplicator
Riso rz 220 the code A17 209 continues to come up
Hello
Yor cutter unit is not in the home position.
Open the front door, take out the master unit, remove the master material, lift the green handle and look to see if you can see a white plastic knob (that is the cutter) make sure it is to the front of the machine, if its to the back of the machine very carefully move it forward until it wont move anymore.
If it is in the front of the machine then the microswitch is probabally faulty and will have to replace the cutter unit.
Regards
May 18, 2011 | Riso RZ220 Duplicator
I can not open the master roll unit. I push the button and do not hear the beep or get a green light. Unit will not pull out
if you look on the front cover of the master roll unit you will see a small round hole take a screw driver and push it in the hole when it wont go in further pull on the lever and the drum should come out
Mar 22, 2011 | Riso RZ220 Duplicator
Riso 390U error code p19 208 .... doesnt seem to be loading the master roll correctly, any suggestions?
Error P19-208
Error type P19: Thermal-pressure motor lock Error point 208: TPH pressure sensor does not go ON within 2 seconds after the thermal-pressure motor activates in the decompressing direction.
Hints: Check mentioned sensor. Check mentioned motor.
Jan 06, 2011 | Riso RZ220 Duplicator
Riso EZ 200E model gives error message A-34 -218 but all seems fine at master roll installation. What can we try ?
It means to reset the master material in the master making unit. Should be ok after that.
Jul 27, 2010 | Riso RZ220 Duplicator
RISO 1610. Start light is blinking. Drum release
Friend,this code refers to switches cover:
can cover the trash (disposal box) that has two switches, magazine master.Tente verify that the drum is in position for opening.
Apr 09, 2010 | Riso Office Equipment & Supplies
141 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
