Question about HP Office Equipment & Supplies
HP LaserJet Pro 400 MFP M425 The ADF won't scan documents. What is the setting?
4 Suggested Answers
printerman40
  • 170 Answers
SOURCE: 4345 mfp hp laserjet adf problem thick line during
Normally, these lines from the adf are caused by a speck or chunk of something stuck on the mylar window...
1. open the scanner lid
2. look on the underside of the lid for a plastic mylar window.
3. the window has a pinch piece on either end allowing the window to be dropped down.
4. either clean this window till its perfectly clear or if it's damaged, your going to have to replace it.
5. in a new printer, they usually tuck an envelope behind the big white square that next to the mylar window and should be sticking out.
6. remove 1 of the mylar windows and replace it, make sure to watch how it comes off in order to replace it the same way. their is a notch on only 1 end so pay attention.
7. if you don't have an envelope , you can order some here. Click Here!!
Posted on Jul 31, 2010
ashu2k7
SOURCE: HP Laserjet M1522NF MFP Scanner adf
i have hp laserjet 1522nf printer and now in printer give a problem scanner error
Posted on Dec 30, 2012
  • 46404 Answers
SOURCE: from computer How can i scan document from HP LaserJet M3035 MFP
From the search I did that printer is not an all in one and does not hacv a scanner function
Posted on Feb 13, 2016
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
I have an HP Laserjet 400 MFP m425dn Everything is working however it now scans very slowly. I don't know what has changed to cause this. Any ideas?
Check what resolution the scanner is set for. It may be trying to produce max resolution when you should be starting at a default of about 300dpi.
May 07, 2015 | HP Laserjet Pro 400 Mfp M425dn...
Laserjet pro black vertical lines using adf
Do regular prints look ok? If so, then try copying something from the flatbed glass. If that copy has no line then you have something on the glass where the paper passes over when fed through the adf, clean the glass well, you may need to use some rubbing alcohol because often fine bits of adhesive from things like sticky notes will cause the lines but are not obvious to the eye when you inspect the glass.
Jul 31, 2014 | HP LaserJet Pro 400 Color MFP M475DN...
Reset password HP LaserJet Pro 400
Where is the go button on the hp laserjet M425dn? I have been trying to reset to default setting, student put a password on the printer.
Dec 05, 2012 | HP Laserjet Pro 400 Mfp M425dn...
HP LaserJet Pro 400 MFP showing offline when printing
My computer says that the printer is offline and my printer will not print idk what to do... suggestions????
Oct 10, 2012 | HP Laserjet Pro 400 Mfp M425dn...
42 people viewed this question
Seeker5211
Seeker5211
