Question about Garden
Cannot get the gas cap off and on without tools on 18 inch Poulenc pro chainsaw
    Sergeant:
  • 342 Answers
Take the fuel cap off with the tools and clean the thread on the cap and inside the saw. It may be a bit of wood chip causing it to lock on.
Posted on May 05, 2017
Gas cap tight and now will not close
What your saying is the gas cap is tight and still leaking gas?
Check the underside of the cap to see if the rubber gasket is missing.
it may of fallen off
Jul 11, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Gas leaks out when chainsaw is tilted and in use
sounds like you have a cracked fuel tank or stripped out gas cap
Apr 13, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
You have to have the choke partially on for the saw to run even after it is warm.Been that way since it was new.
It is running too lean on the mixture screws, unfortunatly the screws will have anti tamper sleeves on, you need to pull these back to richen the mixture, the way to do this without the correct tool, is to find a suitable self tapping screw, screw this into the end of the caps, when the end od the screw hits the screw below the cap will start to draw off, once it has come back enough it will allow you to enter a 2mm screw driver through the centre and make an adjustment to the screws beneath, un screw both screws ( anti clockwise ) 1/4 turn each, they are fuel screws not air screws so this will richen the mixture, try the saw again, if no better try a further 1/4 turn on the L screw.
Good luck
Feb 10, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the fuel mixture for my new Poulan Pro 18'' chainsaw? It looks like 32:1 but not sure.Thanks! Don
If you use a mixture of 50:1 you can't go wrong.This is the industry standard and can be acheived by following the mixture guide lines one the bottle of oil.32:1 will make your saw smoke to the point of being almost unbearable and will foul the plug,so 50:1 is the mix your looking for.
Dec 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have no fire on my pro 40cc 18 inch. what part
new are used coil is what you need distance between coil and flywheel is the thickness of a business card
Sep 02, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Gas cap on the 42cc pro with 18in. bar is very tight.
that is what i did on my table top 1 inch sander first the thread hight then filed the threads edges there is a O-ring to seal the cap remove it before you sand the threads
Apr 29, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
