Question about The Office Equipment & Supplies
Please show me the pictures of the web fuser - The Office Equipment & Supplies
    Master:
  • The Master
  • 641 Answers
Hi . please can you be more specific.
Posted on May 03, 2017
2 Suggested Answers
SOURCE: fuser web
PM is preventive Maintenance - It's kind of like changing your oil! you need to have certain expendables replaced such as Fuser. There should be a P/M kit you can order for this that will include everything.
Posted on May 31, 2008
My panasonic Dp3030 copier shows me call for p/m fuser web what will i do please
Try the default password 00000000 to see if that will allow you to select which setting you would like.
Sep 19, 2013 | Office Equipment & Supplies
OUR PHASER 6180 PRINTER IS SHOWING FUSER LIFE AND TRANSFER LIFE NEEDS REPACING SOON. WHAT ARE THEY AND WILL IT COST MORE TO REPLACE THAN BUY A NEW ONE
Go to this WEB site for fuser parts.
http://www.sparepartswarehouse.com/Xerox,Phaser,6180,6180N,Printer,Fusers.aspx
Go to this WEB site for transfer belt part.
http://www.fastprinters.com/ProductDetails.asp?PARTNO=XER-675K47088
May 16, 2011 | Xerox Phaser 6180N Laser Printer
HP LASER JET 3600 HAS A 50.9 ERROR MESSAGE
However what this 50.2 is telling you is the fuser is bad. You can re-seat the fuser, most likely you will need to replace the fuser.
Based on the manual :
50.9 High fuser temperature (sub-thermistor), or pressure release mechanism problem
I found this link on-line that will show you how to replace the fuser or re-seat it.
Cick Here for Instructions
*Please note the link I'm providing to you, I have no affiliation with this web site in anyway.
Jan 14, 2011 | HP LaserJet 3600n Printer
Blinking h and then 2
this is usually down to the fuser not heating up properly check if you can feel any heat form the fuser section by opening the door to access the area. if no heat the lamp has probably blown or the sensor tripped.
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Does not copy. shows blinking error signal E0-00
This is the error code for the fuser heater lamp failure you will require a replacment lamp of fuser
available from somwere like katun of reprotech all have web sites
Regards Al
May 25, 2009 | Office Equipment & Supplies
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | HP LaserJet 4 plus Printer
Fuser web
May 23, 2008 | Panasonic Workio DP-2330 Printer
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Jan 02, 2008 | Panasonic DP-150A Copier
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
24 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
