Question about Miele Vacuums
My miele S7620 upright cat and dog won't turn on. when i plug it in and turn the switch to on all that hapens is the on light comes on (Red), and thats it.
I have taken the motor out and is spins freely, and so does the brush motor, (cleaned and replaced), the circuit board up by the handel looks ok, nothing obvios looks like its blown. and yes i have checked for blockages in the hoses, and there clear. now i'm stumped?
reddevil6
  • 1673 Answers
SOURCE: New Miele Red Star - Powerbrush not working
Wish you had listed the model number of the vac and of the powerhead. The plug going into the cannister, is it pushed all of the way in, also same for the plug going into the hose end? You can hook up the powerhead plug to a/c and see if it runs, if it does, then it is ok. Unhook the hose and plug and hook up a/c to that plug end and see if the powerhead will run, if not maybe the switch on the hose handle has a problem. Otherwise you have a problem in the cannister. If this is brand new, then it has a warranty, take in for repair.
Posted on Feb 22, 2008
reddevil6
  • 1673 Answers
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Posted on Mar 22, 2008
  • 195 Answers
SOURCE: Reset light is on.
set big Cat to stay on porch. (Smile)
Posted on Dec 07, 2008
SOURCE: DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Posted on Jun 01, 2009
  • 4088 Answers
SOURCE: brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Posted on Jul 12, 2009
I had just changed the belt and I turned it on to see how it was working , and I noticed that it sounds like the motor is working hard
Take the belt off machine, try machine with the belt off, if motor sounds OK, try spinning the brush before putting belt on, if brush does not spin freely, see what is clogging it.
When brush spins freely, reassemble correctly and try.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 24, 2016 | Kirby G6 Bagged Upright Vacuum
Brushes do not turn when vacuuming
Nancy,
More than likely you have a broken belt. If you try to spin the brush by hand with the vacuum unplugged and it spins freely, your belt is broken, or has come off the roller or motor shaft. If it will not turn freely or does not turn at all when you try by hand, you may need to replace both the belt and the brush. You can first look at both ends of the brush to see if there is a build up of hair or string etc. around the brush bearings. If there is clean that off and see if the bearings spin freely. Also, let us know what type of vacuum you have so that we can give you more detailed information that would help you better. Hope this helps!
Apr 30, 2015 | Vacuums
Bissell 687C Vacuum wont turn on
Try to check the circuit... as when there is an circuit fault it gains high amperage and hence fuse shut the current till it regain. It happens to save your device.. don't be doctor. Get it done by authorized person or somthing or it will cost your more then your device cost...
Mar 15, 2014 | Bissell Vacuums
Miele Vacuum Cat and Dog Upright S7260 Loss of Suction
could be a couple things first make sure the hose is clear check real good the other is make sure your bag is good and tight and clean and make sure you have no holes or tears in the hose
Mar 07, 2014 | Miele Vacuums
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
Hose has split
VacuumSpot are miele agents for Australia and New Zealand if you need any Miele parts in this area you can hit us up on the contact us page and we will get you anything you might be after
Feb 12, 2013 | Miele Vacuums
The motor driving the brushes does not start or function in any way. It has been thoroughly cleaned and the bearings look good and the brushes rotate freely when the mach is off.
There are two conditions that cause the brushes not to spin. One ia a cold solder joint on the paddle board connector of the Cleaning Head Assembly and the other end that connects to the brush motor may also suffer From the same condition. Here are some of my photos to reference
http://www.robotreviews.com/chat/viewtopic.php?t=10231
Jan 09, 2011 | iRobot Roomba 530 Robotic Vacuum
Vacuums Logo
80 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
