Question about Tablets & eReaders
My mikona tablet will not load. It goes to connecting to Android then looks like it will load then goes back to waiting for android. Also cannot reset
  • 140 Answers
Posted on May 04, 2017
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
  • 17 Answers
SOURCE: looking for driver for imito am801 8" tablet for Android 2.3
.I know a wholesale online store. you can buy android 2.3 that have good quality and reasonable price will make you satisfied,.hope you can find the suitble that you need.good luck.
Posted on Apr 26, 2012
  • 37 Answers
SOURCE: how to unlock my android cruz
Try the two solutions described by this link
Posted on Nov 29, 2012
SOURCE: forgot login for Craig 7" Android tablet
how do i do a hard reset on a craig cmp741d 7-in touchscreen 4.0 android tablet
Posted on Feb 10, 2013
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
Sep 30, 2016 | Tablets & eReaders
How do I update android on a mikona tablet
Almost all Android devices update in a similar way but the exact steps vary from one version of the Android software to another. So in general... from the main screen select Settings and then look for 'Device' or 'My Device' or on some newer models look for a 'More' icon. Then look for 'Software Update'. That will usually show an option for checking for updates.
Note that almost all Android devices now being sold are configured by default to automatically check for and apply updates.
Good luck.
Mar 21, 2015 | Tablets & eReaders
How to reset tablets
Do a hard reset, press and hold the +vol button, then the power button, wait about 20 seconds both buttons held till the start android screen appears. Hope that helps
Mar 24, 2014 | Proscan 7-Inch Android Internet Tablet,...
Tablet is stuck on the screen that says android
You may have to reset the tablet to factory settings. This may be the only way. It will wipe all the data on it.
To factory reset:
1. Press and hold power plus volume up until an android menu appear 2. Use the volume keys to navigate and option key or power to select. 3. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
Feb 04, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Wont go to log in and internal keyboard stopped working
It seems the system keeps busy starting up, checking and loading drivers for internal hardware or it tries to connect to something, but keeps on waiting for confirmation that it's found.
While undergoing this process, the operating system doesn't get a chance to load the software/drivers for your keyboard.
If there's a reset-button to return to original firmware, try to go for this. If this is not possible, you might have the option to use an flash-drive including the Android-version for you tablet and booting, re-installing Android from it, back to your tablet.
Oct 18, 2013 | Generic A13-MID 1.2GHz 512MB 4GB 7"...
Start up stuck on yes optus screen
You maybe able to RESET the tablet.
There maybe a pinhole RESET button on the back of the tablet. Insert a straighten paper clip into the pinhole RESET button to reset the tablet.
Mar 31, 2013 | ZTE V9 Smartpad Android Internet Tablet
Tablet freezes on boot up at android screen
Do a factory reset. Turn the tablet off. Wait 10 seconds or so. Hold down volume down button while pressing the on button. Keep holding down both buttons until you see an android icon. It may be laying on its back with a red exclamation mark over it, like I saw. Once you see the icon, let go of the buttons and press the "back" or return button. This should bring up a list of options. You can scoll through the list by using the up or down volume buttons. I picked the option to delete all user data, which basically will set the tablet back to factory settings, like when you first got the tablet. Once that is complete, reboot the tablet.
Mar 24, 2013 | Iview 760TPC Android Tablet, ARM Cortex-A8...
Tablets & eReaders Logo
185 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
