Question about The Health & Beauty
What are the benefits of using epilators to remove hair?
    New Friend:
  • 4 Answers
Epilator is a lot more beneficial then using old methods for removing hair. As it helps you to save a lot more time that waxing does not do. It is less painful. Helps one to get smoother skin. Improves the circulation of the body. Can make you feel fresh and energized. And a lot more benefits are there that you can have a look at from
How to Exfoliate Legs. To get more better options for a person to get their skin look smoother and you can also buy the best epilator from there to buy it after looking for the reviews on it.
Posted on May 03, 2017
Emjoi light caress epilator jammed
The major reason that epilator shavers stop working is because of hair that is caught inside the machine. If you have taken the top off and cleaned it out thoroughly using the brush, then this likely isn't the cause.
Is it still under warranty? if so, i suggest that you contact the manufacturer and ask where you can send it for fixing. if your warranty has run out, you can still ask the manufacturer for a list of approved repair shops.
Feb 26, 2013 | Emjoi Light Caress Gold Corded Epilator,...
My Silk Epil 7 has stopped working, the epillator head has stopped rotating. I doubt that some hair has got stuck inside. Could ypu please help?
My Braun worked fine the last time I used it & would not come on when I tried it today. Worked on it & found it to be jammed with hair. Would not rotate. Scrubbed it with a toothbrush, started digging out the hair, forced it to rotate, scrubbed it some more, & rotated it some more. The more I worked with it the more hair kept coming out. It's rotating fine now. I think I'm going to clean it with my water pik. My Braun is the kind that can be used with water & the top part comes off. Haven't used it yet but I think I have fixed it. Wish I could get it apart to clean it out but the head of the screw is strange & I don't have anything that will turn it.
Aug 31, 2011 | Braun 5270 Epilator
Silk Epil 5376 Rotators are too slow and it doesn't work like it used to. When you take the head off the spinner spins fast but when you put the head back on it is slow and then the tweezing heads do...
You will need a star-shaped bit to remove the 2 screws. I would imagine they’re metric as it’s made in Germany. Barring that, a small flat head screwdriver used for eyeglasses will work. Remove the screws over a bucket or something so you don’t lose them, because they’re specific to the SilkEpil and can’t be bought at the hardware store.
When you remove the screws and take it apart, you’ll see the gears inside are clogged with hair. The flaw with the design is that the gear mechanism will suck in a few hairs every time you use it, which build up over time.
Remove the gear unit and use tweezers to pull out all the hair. You can rotate the gears to get it all. On the underside of the tweezer section, there’s a little recessed gear that’s probably clogged with hair too. Rotate the tweezer barrel to turn the little gear, and pull out the hair.
Give everything a good rinse, put it back together, and let it dry overnight. Presto, good as new!
I plan on doing this once a year as regular maintenance.
Aug 13, 2011 | Braun Silk-epil 3370 Epilator
How to clean a remington EP6010 epilator?
CLEANING THE EPILATION HEAD Ensure the epilator is turned off and disconnected from the mains. Press the head release button/s and open the head assembly. (Diagram G) Turn the head assembly upside down. Using your thumbs, push the small sides together and push the epilation head upwards. This releases the curved epilation head. Brush the accumulated hair from the tweezers by turning the barrel manually. NOTE: The body of the epilator is not washable. Do not submerge in water.
TO REMOVE RESIDUE To remove residue from the stainless steel tweezers, dampen a swab with alcohol. Gently run the swab over the tweezers until the residue has been removed.
Online Manual:
Feb 28, 2011 | Remington Health & Beauty
My Mom order this product and never used it. She
This interchangeable tweezers device (pat. pending) will do wonders for the way you feel about yourself. When you follow these simple instructions, Emjoi Beauty Forever will rid you of unwanted hair for the long haul! You can decide whether to use the coil-tweezers or the gold-plated tweezers based on these broad criteria:
The coil-tweezers enable you to clean out at a time a multiple number of unwanted hair (most notably, at the bikini line and some facial hair).
The gold-plated tweezers are intended to remove individual unwanted hair (like those on the eyebrow or on the breasts).
To use Emjoi Beauty Forever efficiently, please read carefully the enclosed Instruction Manual and pay a special attention to the following:
Clasp the unwanted hair with the Emjoi Beauty Forever's coil tweezers or gold-plated tweezers. At the same time, press the handle button for 15-20 seconds. The indicator light on the inside panel (near the adapter outlet) lights more brightly and will remain so during the application.
Slide the hair out gently in the direction it grows. If the hair doesn't slide out easily (some hair is more stubborn than other), gently tweeze it out. Even the coarsest hair is removed with a lasting effect by the Emjoi Beauty Forever's unique epilation treatment.
These helpful tips will assure extra-effective epilation!
The shorter the hair, the better the results. Preferably, hair should be no longer than 2-3 mm (1/10 in.)
Your skin should be completely clean before treatment.
To make skin more supple and relaxed, wash with warm water and gently massage.
Make sure no radios, TVs, or cordless phones are operating during treatment since they may interfere with RF transmission.
If a hair remains after 3-4 consecutive treatments, tweeze it. It has been sufficiently treated. There are some hair roots that need more treatments, particularly those that are dark and thick, or near throat, chin, lips, thighs and bikini lines.
Mar 08, 2010 | Emjoi Beauty Forever Epilator
Where to find?
You really don't need instructions. Just got over area using a small circular motions. I just keep going over the entire leg this way until all hair is removed and yes there will be some pain (especially if you have never experienced waxing!).
Jul 31, 2009 | Epilady Classic Epilator
Silk epil----Ouch
get drunk first?  take drugs?  Ripping hair out by the roots hurts!  I never managed to finish one leg so you're doing pretty good.
Oct 13, 2007 | Braun Silk-epil 3370 Epilator
Health & Beauty Logo
32 people viewed this question
Top The Health & Beauty Experts
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
