Question about Electrical Supplies
My Powerfit has caused a circuit breaker at my home to trip. I have tested it on several power points and it still trips the circuit breaker. What would be the problem and where can I get it fixed?
  • Electrical S... Expert
  • 153 Answers
We have videos on how to test them on our website.
1st you need to decide if you have brushes on the alternator or not. To do this remove the end plate and see if there are wires going to a plastic or metal housing located on the bearing plate at 12 o'clock. Like shown in this photo:
Once you have determined if it has brushes or not, then watch our video on how to test them here:
Hope this helps! If you need more advice please contact us via our website :)
Posted on May 04, 2017
    Top Expert:
  • 12,744 Answers
Notify powerfit for a repair location in tour area
Posted on May 03, 2017
get in an electrician to check the equipment and the circuits
Aug 29, 2017 | Heating & Cooling
Curcuit Breaker appears to be on but no power?
It sounds like something in that circuit is causing the overload. Disconnect anything that is in that circuit, flip the breaker, and one item at a time plug whatever was on that circuit back in until it trips again. Then try that item in a different circuit and see if it does the same thing. It could also be that the breaker is worn out and is tripping at a lower point that it supposed to. In that case you would have to replace the breaker.
Mar 04, 2015 | Electrical Supplies
My fridge keeps tripping the power
Your solution is one of two things.
First is the circuit you have plugged the refrigerator is either over its limit and the breaker is tripping because it is overloaded. In this case you will have to determine what load also share this circuit and eliminate the extra loads or move the cord to another circuit which is not overloaded. Most home circuit are wired with 14 gauge and is rated at 15 amps. When the circuit gets to 15 amp and more, the associated breaker trips to prevent overload.
Second, Your refrigerator may have a short and needs troubleshooting to find the cause. To see if it is a bad circuit try plugging into a circuit via extension cord to circuit in another room receptical. The reason I say another room, when electrical installers wire circuits, you can put several recepticles on the same circuit. If you plug your refrigerator in the same circuit you had it on before then you will get the same problem, your refrigerator tripping again. If your frig trips on a different circuit then troubleshooting the cause will normally require a tech.
Good luck and hope this helps.
Oct 28, 2014 | Refrigerators
Home electrical
Hi Sammy,
It sounds like there is a direct short on the circuit. Before going any further, check other outlets on this circuit and make sure they do not have anything plugged in that is not expected and does not work. Check OUTSIDE your home, basement, garage, etc. as these locations require GFI protection - and may be fed from the bathroom outlet. After removing devices that are plugged into the circuit, attempt a reset of the breaker once more.
It is not likely that the circuit breaker has failed (but is a possibility). The outlet in the bathroom is probably a GFI type. You can determine this if it has "Test" and "Reset" buttons on it. You should be able to press the Reset button in fully even with power off. After resetting, you can attempt the resetting the circuit breaker as you have described above. If it stays on, try pressing the "Test" button on the outlet. Doing so should trip power to the outlet (and causing the "Reset" button to pop out) but leave the circuit breaker "On". If the breaker also trips, the GFI outlet is suspect and might need to be replaced.
At this point, a qualified electrician should be consulted to locate and clear the wiring fault.
Apr 24, 2013 | Hammering
Circuit breaker trips after water supply cycle
check the condensor fan in the compressor area and make sure its running if not the compressor will overheat causing high head pressures on the compressor causing it to draw too much current to operate the compressor and kick the breaker out,also make sure the condenser coils there are clean and it has ample air movement away from the wall
Apr 21, 2013 | Kitchen Appliances - Others
Breaker trips after bout 5 minutes
Breakers trip because of heat.
When heat from wire exceeds breaker rating, it trips.
Something is causing heat on the wire, wire is too small for the amp draw, there is short circuit, or breaker is bad.
Replace breaker and/or test wire.
Put amp-meter on wire and read amp draw through wire.
Amps cause heat. That's why high voltage lines from power station are high-volt-low-amp so there is no heat loss with long distance transmission, until transformer at home converts electricity to lower volts and high working amps with enough power to run electrical devices.
Same is true for AC and DC circuits.
If amp reading on wire exceeds rating on breaker for length of time, then breaker will trip.
The fact that the breaker lets current (amps) to flow for a period of time before tripping is because the breaker is probably rated for slow-acting, or it takes a while for amp draw to heat the wire.
Following image shows amp-meter that clips over wire to get amp reading.
Oct 31, 2012 | Electrical Supplies
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
Intermatic t10004 control panel trips the circuit breaker
That circuit breaker is letting you know that you've got a problem in the electrical wiring.... What's next is to turn the power off to BOTH legs of the breaker.
Begin by physically inspecting all the connections in the timer box, and at the breaker and all the way to the pump motor. Make sure all connections are dry, and there's no water in any of the conduits...this will cause a short circuit and trip the breaker. If there's any bare power leg wires touching a grounding point , this can cause the breaker to trip. Lastly check the motor on the pump; on the motor end, there should be a cap you can remove and use a crescent wrench to make sure the motor shaft is moving freely. It could be jammed with debris....this happens around my pool often because I'm surrounded by trees with needles. If the motor cannot turn freely, this will cause the breaker to blow... I'm pretty sure that your timer isn't the issue... Please let me know what you find out.
Nov 19, 2009 | Intermatic T10004R - Pool-Spa Mechanical...
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
Electrical Supplies Logo
53 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
