I would like to know how to fix a torn film of bizhub c 220 transfer belt. Thank you. Uchenna.
4 Suggested Answers
  • 170 Answers
SOURCE: Filming transfer
Several steps are involved. You will need a firewire or USB cord to connect your camera to your computer. You will need a video capture application on your PC. Macs come with this program, I-Movie. Once captured, the movies can be edited. Your PC will need a combination drive to burn a DVD from the captured material. An easier way: Take your camera output and feed it directly into a DVD recorder. No editing, but it is a one-step process. I use both methods.
Posted on Dec 12, 2008
  • 62 Answers
SOURCE: torn transfer belt
quite straight forward, but obviously tricky the first time. Basically take off all the brackets on the top and on the outboard end of the belt assembly there is 2 more brackets screwed onto the side. Remove these (5 screws in total i think) and then release the tension roll (the one that pushes up on the left hand end if uyou have just took the right brackets off. The tension roll can be held in a non tension position while the belt is removed/replaced. Let me know how you get on or for further help
Posted on Mar 20, 2009
  • 3085 Answers
SOURCE: Xerox M24 Transfer Belt Torn
Posted on Sep 09, 2009
How can I enter system error clear in bizhub c 224e printer? Thank you, Uchenna.
Hope this helps
May 29, 2017 | In Office Equipment & Supplies
How can I solve colour registration error in konica minolta Bizhub c 451 printer. Thank you, Uchenna.
run registration procedure in service mode. any p codes check the black image unit as is the reference for color registration
Mar 18, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
My printer fuser and transfer belt did not open with error code c2152 i tried to reset the printer but not still working pls what can i do
1. Detecting Plate not positioned properly.
Shape of the detecting plate has been modified. Install the modified Detecting Plate (p/n A02E 5033 01). Please refer to the attached procedure for
instructions on how to install the modified bracket.
Note :The following are the serial number cut-inswith themodified Detecting Plate installed:
bizhub C353 - A02E010005899 and onward
bizhub C203 - A02E012005777 and onward
bizhub C253 - A02E011005566 and onward
bizhub C353P - A02E013000060 and onward
magicolor 8650 - no cut-in available
2. Transfer Belt Retraction Sensor (PS31) mounting bracket (p/n A02E 1121 00) is fixed with a screw and it can be tilted while assembling. If the bracket is
tilted, the sensor cannot detect the Transfer Belt position properly. In order to avoid tilting the bracket, the shape of the bracket has been changed.The shape of the sensor actuator has also been changed because the actuator could touch the other parts.
A02E 1121 00 -current Bracket
A02E 1121 11 - modified Bracket
A02E 1122 01 - current Actuator
A02E 1122 12 - modified Actuator
Notes :
a.When at the machine, please check the condition of Sensor Bracket and change the Sensor Bracket and Actuator if necessary.
b. Please refer to details in attachedBulletin Number 6252 (applies tobizhub C203/C253/C353).
3. Somepacking material was not removed froma new Transfer belt before installation. Ensure that allpacking material has been removed before the Transfer belt is installed.
4. Failure of the Transfer Belt Retraction clutch (CL7).
Check for wiring being pinched from bypass door and replace the failed parts.
CL7 (p/n A02E M200 00)
bizhub C353 Drive Wiring/1(p/n A02E N10F 02)
bizhub C253 Drive Wiring/2 (p/n A02E N117 02)
bizhub C203 Drive Wiring/3 (p/n A02E N10Y 02)
bizhub C353P Drive Wiring/4 (p/n A02E N11A 00)
magicolor 8650 Drive Wiring/6 (p/n A02E N11C 00)
Mar 16, 2015 | Konica Minolta Minolta Bizhub C353 Copier
Error Code C2152
Transfer belt code was it replaced properly?
Apr 17, 2014 | Konica Minolta Full Set For Bizhub C220...
How to know Transfer Belt fuse is gone
The fuse blows as soon as its put in the machine. Thats how the machine knows to reset its count
Dec 20, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
How to know bizhub c451 Transfer Belt fuse is gone
The fuse blows as soon as you install the transfer belt. Thats how the machine knows it has been replaced.
Dec 20, 2013 | Konica Minolta bizhub C250 All-In-One...
Problem with copier "Rex rotary - DSc232"
Hello velin viv,
The copier does not see the proper operation of the transfer belt. This is a film belt that is part of the development of the image and transfer of the image to the paper. Its critical movement is monitored. SC 481 means that either the belt is not moving, or the sensor that monitors the belts movement is bad,or the belt has torn and is physically unable to be monitored, or (save the best for last) the main controller has lost its mind and does not recognize the inputs it is given. I wish I could help you further. Typically the belt is torn, from simple wear.
Jul 04, 2008 | Gestetner DSc232 Copier
