Daikin Rpz1450 ducted aircon/heat inverter. Freezes over on the core and shuts down when ambient temp a bit low. What has to be done to get it to cycle properly when in it goe sinto deice mode?
SOURCE: daikin aircon f22jtns
Posted on Nov 24, 2008
  • 311 Answers
SOURCE: whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
  • 449 Answers
SOURCE: 1998 GMC Jimmy SLT warm air only from heating ducts
if you claim that your heater core is flushed properly then my bet is the temp regulator is bad.
Posted on Jan 13, 2009
  • 478 Answers
SOURCE: Heat pump cycling on and off.
It sounds as if you you have a low charge of refrigerant, r22. When the unit comes on outside, the outdoor coils become the lowside, there is a low pressure switch that is tripping out contactor protecting the compressor.
Posted on Mar 11, 2009
  • 2133 Answers
SOURCE: I have a Daikin split
E5 Outdoor activation of compressor over heatprotection or motor lock
Check condenser coil. If dust blocked-clean it.
Check out door fan motor is working. If not replace capacitor or motor.
Check compressor-gradually amps increasing-replace capacitor.
Check for gas pressure. No gas also gives over heat compressor.- Leak test and rectify.
Posted on Jan 16, 2011
Kolin inverter window type aircon shut down with FO code
when you post the same question more than once in a few hours most here tend to ignore them. once is enough. when someone who knows the answer comes on maybe youll get lucky.
Jan 28, 2018 | Inverter Heating & Cooling
What does external protection devices activated mean? ( EO code)
these are saftey swithes that are used say if your out door unit fan quits the compressor will run hot and shut off or if your indoor unit is stoped up the unit will run low pressure wich will shut off by the low pressure switch usually if its dirty or low on freon it will come on and off three times or so and will shut its self off.
Jul 20, 2014 | Daikin FDXS12DVJURXS12DVJU Slim Duct...
My 2004 e270's second battery "died" and was replaced. How I realized this was the aircon went into "off-mode". The AC is now working again but not at the same chill as before.
For an ac to work there has to be heat in the cab to evaporate the gas after it leaves the TX valve . Check that if the ambient air temp is well down then the ac temp may not be as good as it could be expected on a hot day. Check that the ac clutch is engaging and you are not reading ambient temperature through the system
Dec 05, 2013 | Cars & Trucks
Error code e4 on daikin split system ducted air conditioner - what does it mean?
This is stating that there has been a low pressure error on the system.
This could have been caused by a blockage in the pipe work or a possible shortage of refrigerant. It could also be due to a fault with the low pressure sensor/switch.
Jan 31, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
I have a Daikin split system ducted aircon. temp on 22degrees.turns off error code flashes E5, and a picture of a spanner
Jan 16, 2011 | Heating & Cooling
I have a GrandAire and the aircon works fine; when I turned the heat on, it seems to work fine (warms the house), but the fan in the outside unit is not spinning when the heat is this a problem?...
I think your unit is working in good condition. If you keep in cool mode the out door fan runs to condensate the heat in condenser by taking fresh air from the ambient. And when you keep heat mode, definitely the ambient temp will be too less.I fit takes from their then compressor will get frozting and it couldn't work properly. Depending on pressure increase, the fan will automatically run and stop. Don't worry. Thanks.
Dec 16, 2010 | Heating & Cooling
I have a Goodman condensing unit that freezes up occasionally during low ambient weather (20 F). Model # ssz160361ac with matching new air handler. I have adjusted the defrost time from 90 to 30min. This...
It is not freezing up because of the temperature, but because of ice being formed in inside. Either by a blocked condensation duct, or snow due to previous storm.
Jan 31, 2010 | Goodman Heating & Cooling
Heater blows out lukewarm heat after car is warmed up
Does temperature of heat increase at all, when RPM's of engine increase?
Cool when idling, warmer when engine is revved a bit?
Dec 27, 2009 | 1997 Ford Taurus
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Appliaance shuts off at low temperatures
Most refrigerators cycle on and off based on the fresh foods temp. If the ambient temp is 10C and you have it set for 4C, the unit does not have to run much to satisfy the temperature control, and the temp in the freezer section will warm to + C range. (likewise, if the ambient drops to -C range, it won't mater if you set the fresh food section to +4C, it won't heat the air, and the fresh food section will eventually reach the -C ambient temp.) The only solution is to move the appliance to a warmer location or heat the room it is in. This is the only Fix-Ya for your refrigerator.
Jan 03, 2009 | Refrigerators
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
