Question about Grundig Audio Players & Recorders
I have bought an as new grundig opus dab radio with remote control. There is nothing in the manual about the remote and I can't use it. Any idea how to connect it or use it. Batteries are new. Brian
SOURCE: users manual for the grundig g5 shortwave radio
I can't find one either but there is a downloadable manual for the Eton E5 at Retrevo.com  Just search for Eton E5
Posted on Feb 28, 2008
SOURCE: wharfedale dab radio da-110e
According to the manual the indicator lights go out when the batteries are charged.
Posted on Mar 30, 2008
IrishDruid
  • 2712 Answers
SOURCE: To reprogram nextech 1519003b
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: Setting the reset stations on a DAB radio
I used lateral thinking! looked at the instructions for my other matsui DAB radio and worked it out from there. With this Ferguson model you have to find the station you want manually and then press one of the preset buttons (it only has 4 but these are enough for me)
Posted on Jan 11, 2009
SOURCE: Grundig yacht boy 400 radio does not work with mains operations
hello i have a grundig mini-300 radio , the volume control is stuck in high range . i have had many problems with this radio , i would love to talk with one of your representives . please call me at 585-313-3188,,thank you ,,,,nicholas ferrara
Posted on Aug 19, 2009
I bought a Bush digtal/ AM/ FM radio ("retro transistor" style). DAB reception dropouts lasting several seconds each time have started occurring recently. AM/ FM is ok.
Constant usage of DAB should not cause it any damage ever. The dropouts are very characteristic of a poor signal reaching the DAB tuner, as digital is either there, or not there, nothing in between.
Check the aerial connection if any, the rod antenna if any, and try moving the antenna (whatever it is) to a better location, usually higher up, away from thick walls, and away from speakers if any.
Apr 18, 2015 | Grundig FR200 AM/FM/SW/DAB Radio
DAB radio DR1302
You can get here manuals for dab, though I couldn't find your. Maybe there is one similar. Check it.
Dec 30, 2013 | Televison & Video
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Decode my car radio
The code for GR0971T6197837
is 2 8 8 6
Nov 03, 2009 | Grundig G4B AM/FM/SW/RDS Radio
Users manual copy of a Grundig satel.antenna positioner AP 201 ?
Do you still want it ?
I have copied it on pdf
tvsateq@gmail.com
Oct 08, 2009 | Grundig FR200 AM/FM/SW/DAB Radio
The radio says safe
To reset from SAFE leave SWITCHED ON...UNDISTURBED until it has automatically reset itself. This could take several hours.
For a code, quote the MAKE+MODEL of radio plus ALL the LETTERS+NUMBERS on any LABELS,BARCODES or STAMPED IN THE METAL CASING
Jun 27, 2009 | Grundig FR200 AM/FM/SW/DAB Radio
Grundig car radio codes
There are 3 ways you can get the radio code:
1. Reference your car manual or the Grundig's manual that came with the unit. Most times, there is a sticker on the manual with the radio code printed;
2. Call/visit the car dealer and explain your issue. You may need to show proof of ownership of the vehicle and/or the radio;
3. Use firms who specializes in this. You can try here, here or here.
If the Grundig is the original radio installed when the Vauxhall Astra was new. there are some unconfirmed reports that the radio code is also stenciled on the metal plate where the Vehicle Identification Number is.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 22, 2008 | Car Audio & Video
26 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
