Hello,I had front loading Dawoo washing machine model # twd-wd1132, I want to make service. Kindly advise me location and contact details please.
2 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: Washing Machine Service station
Company:EKL Appliances Limited (not a subsidiary of AB Electrolux)Address:Global Business Park, Tower-A, 3rd Floor, Mehrauli - Gurgaon Road, Gurgaon - 122 002Tel:(91)-124-280-3250/280-3260Fax:(91)-280-3292 Got Backup?
Posted on Feb 10, 2008
Do I have to take apart the whole machine to fix the drain pump on my LG WM3455HW washer/dryer combo? I can't seem to find any instructions on this model.
Lucky You. The newer models of LG Combo units WM34xx have the filter on the right hand side and the pump can be changed through the bottom panel.
Nov 17, 2015 | LG Washing Machines
Where is the switch located on the front door of front loader washing machine
Hello Friend, that's a great question!
In order to provide you the correct location of the door switch on your Frigidaire front load washer, I will need your model number. The serial tag, which lists your model number, is typically located on the upper front, as you open the door. Thank you! - Z
Jun 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
How to operate frigidaire washing machine, ill dont have a manual since i bought it 2nd hand ...
Hello Ruby Torres - I understand that you will like instructions on how to operate the washer, however may I please have the model number so I can assist you better in pinpointing you the information. Generally speaking, the serial tag on a front load washer is usually located on the upper front, as you open the door.
Dec 16, 2012 | Frigidaire ATF6000ES Front Load Washer
Where can I contact the nearest technician? We are in Bulacan area.
Hello
You can use this service locator form Electrolux:
Electrolux Service
Then choose Central Luzon and then choose Bulacan.
Thanks for using Fixya!
Rate my answer if this helped you.
Sep 12, 2011 | Electrolux EW1000i Front Load Washer
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | LG WM-1832C Front Load Washer
Dyson croi front loader showing up fault 6 please advise re same
Hi its Darran at Dyson.
So that we can help you with this issue, please contact our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
We look forward to hearing from you.
Kind regards
Darran
Dyson Customer Service
Mar 16, 2010 | Dyson CRO1 Front Load Washer
Hotpoint First Edition FEW10 filter/smell
Filter is located in the big hose from the drum to the pump, called the sump hose
Access is via a removable panel at the rear of the washer. remove hose and clean filter.
Aug 07, 2008 | Hotpoint First Edition FEW10P Front Load...
Feb 10, 2008 | Electrolux EW1000i Front Load Washer
Frigidaire Washing Machine Model 975FS2
all wsher have bearings which hold the drum centrally if these are worn than the machine will make a noise and get louder on spin and will only get worse sometimes cheaper to replace washer than it is to fix your bearings sorry m8
Aug 11, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
