Question about Health & Beauty
What milage will a scooter do at 8 mph - Health & Beauty
    New Friend:
  • 46 Answers
No clue.
Posted on May 03, 2017
Can someone tell me please what top speed is for this scooter and what weight it handled
Generally the disability scooter is available in a 4 mph, an 8 mph version or a dual version that can be switched between both those maximum speeds..
I think I read somewhere 18 stones is the test weight. A heavier load could be carried but the machine won't accelerate as quickly and the climbing ability will be reduced and so probably will the range.
Due to the bought-in nature of many of the components, standardisation is virtually impossible and so there will be variations in spec. naturally between models and between manufacturers so it is best to check with the manufacturer of your machine or a dealer with experience of your machine.
Dec 18, 2016 | Health & Beauty
2014 Jonway YY250T 125cc Scooter..What type of carburetor goes in this scooter?
Hi, Terry I believe it is a WHYJO or ASIN B008AD23FO for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Amazon com Chinese Scooter Parts GY6 Jonway NST YY250T Carburetor...
Chinese Scooter Parts GY6 Jonway NST YY250T Carburetor Unimerc Amazon...
Service Support China Jonway Group
Jonway motorcycle manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 21, 2016 | Goes Motorcycles
I HAVE A CRAFTMATIC COMMANDER MOBILITY SCOOTER I NEED A MANUAL PLEASE, ALSO DOES ANYONE KNOW IF IT 8MPH CLASS 3 OR NOT..THX
hi, it 's actually made by pride and yes it is a rated class 3 mobility scooter capable of 8 mph...
  • Pride Craftmatic Commander (CRM2700)
Regards
Rob
Apr 27, 2016 | Health & Beauty
Had brushes replaced on my pride executive scooter but now seems to move a lot faster when just touching the control, I have to have it on the lowest speed to get out of shed and still seems to quick
hi Linda, okay let recap what you have to slow the scooter down , it 's a very fast scooter however you have the speed control located on the tiller and you have the 4 to 8 mph switch located there as well, now they can go faulty and appear to have no effect , have you tried adjusting them ?
Regards
Rob
Dec 08, 2015 | Pride Health & Beauty
Mobility Scooter 8MPH ROAD OFF ROAD COUNTRYMAN BATRICAR
Hi, before i advise you is it possible to see a picture of the scooter in question ?
Regards
Rob
www.gewizrepairs.co.uk
Feb 12, 2014 | Pride Go-Go Elite Traveller Plus HD...
I have 2005 model,pulsar 150dts-i,i am getting milage of 30kmpl,how to increase milage and what is basic milage of 2005model pulsar 150cc
Hi Deepu11007, the following tips are low cost easy to apply/install and guaranteed to give you better gas mileage and a smoother running bike. The average motorcycle gets 35-40 MPG. saving .2 gallon of gas could save you a 6-mile walk. 125cc scooters have been known to get 115 plus MPG
1. Proper tire inflation as per MFG. specifications wheels should be balanced and spokes tight.
2. Oil and coolant levels maintained at full marks, low levels produce excessive heat that causes the engine to work harder and reduces efficiency.
3. Keep extra weight to a minimum.
4. Take off from a dead stop should be smooth and easy throttle applied avoid excessive throttle snaps.
5. Smaller windshields get better MPH than large ones, wind resistance increases as a square of the speed at which you're traveling. So, for example, at 70 mph, wind resistance is double what it is at 50 mph (70 squared is almost twice as much as 50 squared). Thar will drastically reduce your mileage. Keep that in mind while biking.
6. Keep idle time to a bare minimum or turn off the engine.
7. Re-jet carburetor with a smaller main and mid-range jet.
8. Keep chain/belt properly adjusted.
9. Avoid quick braking, hasty acceleration, high-speed driving, try driving the speed limit and keep a constant speed.
10. On long trips use freeways or flat straight stretches of highways rather than city or rural routes avoid hills and mountains when possible.
11. Keep your engine clean, dirt and grease/oil hold in heat.
12. A full-face helmet is more aerodynamic than other types of helmets. Any other clothing that decreases your aerodynamic should be reconsidered.
13. Any unnecessary bling on your bike is going to decrease fuel efficiency.
14. Use high-quality fuel using low-quality fuel can cause sludge in your fuel injectors.
15. Keep warm up time to a minimum get off the choke ASAP.
16. Motorcycles run best when their engines are maintained, and that includes making sure the air filter is clean, the spark plugs are fresh, the fuel filter is free, and the timing/valves are adjusted.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/bajaj+pulsar+150
Jun 20, 2011 | 2005 Bajaj Pulsar 150
Set to move at 8 mph on full charge speed set to max only moving at 1 mph or less using battery charge in 20 mins
Hi, Sadly that sounds like your batteries have called it a day however please check your charger as this can have a fault and this can make your batteries appear weak and the battery teminal connections, are they loose ?. Check your manual as I think you can fit 12V 40Amp batteries to this scooter.
Please leave feedback if my advice helps.
Jan 17, 2011 | Pride New Mobility Victory XL 4 Wheel...
My 2006 125 4 stroke scooter only does 35 mph
check with a dealer mechanic but generally the scooter is small capacity and depending on your body mass , 35-40 mph is approaching the speed limit of the scooter
Oct 24, 2017 | 2005 Kymco Stryker 125
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
