Question about Refrigerators
I NEED TO REMOVE THE INSIDE PANEL IN THE FREEZER COMPARTMENT AS THERE IS WATER LEAKING
It is aLG GR-389SQF
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
  • 4 Answers
SOURCE: F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
Posted on Nov 17, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: fridge is leaking from freezer to top shelf
This is the drain tube that runs in the back of the freezer on the bottom is pluged. Take a sprayer with some hot water in it and flush out the system. Remove the food so that you dont get any of the stuff on it.
Posted on May 21, 2009
hiltonjug
  • 612 Answers
SOURCE: Kenmore Refridgerator leaking water into
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Posted on Sep 01, 2009
  • 71 Answers
SOURCE: water dispenser line leaking at bottom of freezer
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
Posted on Oct 03, 2009
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
I have Whirlpool refrigerator without ice maker, It leaks water down inside of the crisper drawers . What can be wrong with it
The most common problem is the defrost drain hole is plugged or frozen over.And the defrosted water from the evap coil is leaking in the fridge compartment,You may have to remove the back panel in the freezer compartment and defrost the evap coil and drain area.
Jan 07, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I have water collecting on the iside of the refrigerator compartment. It is leaking through the air vent openings from the freezer compartment.
I am going to assume you have a defrost condensate blockage in the rear of the freezer and behind the rear panel where the evaporator dreains condensate after each defros. Please correct me if I am wrong.
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My refrigerator keeps leaking water. Need help.
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 25, 2009 | Sub-Zero Refrigerators
Ice build up in freezer compartment until water flows onto floor.
Hi, Is this a wwhirlpool brand fridge?
The drain is plugged in the freezer section. If I could get model #,I can get you ezact instructions.
If the floor panel in the freezer has screws holding it in, remove the fllor panel. Now you will need to remove the rear panel inside the freezer as well.
If this is a Whirlpool brand, there is an after market drain heat strip that you will need to add to the defrost heater.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Refrigerators
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Mar 10, 2009 | Refrigerators
Water leaking in refrigerator on shelves, drawers, and under draw
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Feb 09, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
