Question about The Watches
The wrist heart rate of my garmin735xt seems in accurate. when i train my heart rate is often in the no zone or warm up, and is higher when i am not training.
  • 521 Answers
SOURCE: polar f11 wrist watch- at
unknowingly you know the exact problem.change the battery if does not work .take it to the repair center.thanks.
Posted on Aug 22, 2008
SOURCE: heart rate zones
Heart rates are known by the garmin software as zones, numeroted 1 up to 9.
You can set on the software your heart rate, based on :
- HR max ;
- intermediate HR, linked to the zones.
Then, when you upload a session in the software, you will analyze the zones you ran in.
Another tip : to set on the Garmin itself, the Zones to ON,then Z0 to ON, and Z0 HRM to ON : here you can indicate your HRM low (ex : 165 for me) and the HRM High (185 for example). Then during your session, an up or down arrow will appear, indicate if you run below your HRM low (aerobic zone), your anaerobic zone (betwin HRM Low and High) or in VO2 max.
Hoping that's clear and that can help you.
Posted on Mar 06, 2009
SOURCE: wrist watch- at times the watch isn't showing
Manger de la marde vous êtes des crosseurs!
Vous mériteriez d'être poursuivis pour faire perdre tant de temps aux gens, pour vous approprier les solutions que les bonnes gens trouvent et ensuite faire de l'argent avec.
Posted on Oct 27, 2009
SOURCE: I have Sportline S7 Heart Rate watch with no
In checking out information about my new S7 ECG Heart Rate Watch, I noticed your posting. There is a Sportline website that enables you to down the product manual.... although I'm not sure it pertains to the S7. If this doesn't work, I'm sure there is a manual included with the watch I just received, and I'd be happy to email to you. I'll check back to see if you've posted a response here to see if the below website worked for you first. Posted 7/11/2010 by Mary G.
download product manual - HEART RATE WATCH 7. HELPFUL HINTS IN MEASURING HEART RATE. 8. SETTING THE WATCH FUNCTIONS ... stylish LED Heart Rate Watch measures ECG accurate heart rate with the simple ..... HEART RATE WATCH. Sportline® is a trademark of SPORTLINE, a division ...
http://www.cbs.sportline.com/manuals/SP4421IS01SPO1.pdf
Posted on Jul 11, 2010
firesnake09
  • 2923 Answers
SOURCE: where can i get a
I checked the Sportline website (www.sportline.com), but I did not find any info if they're selling a replacement band for your heart rate monitor. It would be better to contact their customer service for inquiry through 888-901-364.
Thank you and good luck!
Posted on Nov 22, 2010
Under the settings, limits, the limits on the max HR stop @ 100. I want to increase the setting on max hr but it stops @ 100 and then returns to 18. help [polar F4]
Go into settings.
Press the center button on the right hand side of the watch 1 time you will see settings watch time & date appear in the display.
Press the bottom button on the right side of the watch1 time to get into the TRAINING SETTINGS FUNCTION.
When you see TRAINING SETTINGS in the display press the center button on the right side of the watch once.
You are in TRAINING SETTING mode.
Press the bottm button on the right hand side of the watch 3 times until you see
ZONE LIMITS displayed.
When you see ZONE LIMITS displayed press the center button on the right side of the watch 1 time to enter into the ZONE LIMITS FUNCTION.
Now, you should see the lower end heart rate limit number blinking.
To adjust this number use the top button on the right hand side of the watch to increase this limit or lower button on the right hand side to decrese it.
When you have it set where you want it press the center button 1 time to save that setting.
Now you should see the upper limit number blinking.
Follow the same steps to set the upper heart rate limit.
When you have pressed the ceter button to set the upper limit you have completed setting the heart rates limits and the display should read: LIMITS SET!
Feb 13, 2011 | Polar F4 Heart Rate Monitor Watch
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
I changed the battery in the f6 . I had erratic readings. Now watch seems fine but it wont read heart rate,,,,I get no heart beat at all .
Check out my tips and tricks section for a guide on troubleshooting heart rate readings.
One other possibility if you changed the battery yourself (never recommended) is that some damage or moisture has gotten into your watch and made it impossible for the watch to read heart rate. This is a more common reason than you think and why all manufactures of Heart Rate monitors and other types of watches have you send them in to their authorized service centers.
Dec 08, 2010 | Polar F6 Wrist Watch
I have Sportline S7 Heart Rate watch with no manual. This model is not listed as an option at www.sportline.com I need to know how to set the time. I also need to know if it has the capability to of sound...
May 18, 2010 | Watches
Wrist watch- at times the watch isn't showing
Oct 26, 2009 | Polar A5 Wrist Watch
Polar F6 - Heart Rate zeroing out during workouts
Use this link and reset your Polar F6 completely:
http://www.polar.fi/en/support/downloads?product=&category=User+manuals
Rate me, please.
Jul 30, 2009 | Polar F6 Wrist Watch
Inaccurate Measurements of heart rate
Replace the battery. Then make sure that it is placed on the proper artery that it is supposed to be on. If your heart rate was 210 you would be in the hospital with a heart attack. And also the only person I know with a heart rate of 90 when running is Lance Armstrong. Your heart rate should be about 120 to 135 and it will just around in those areas but should never go higher
May 22, 2009 | Polar F6 Wrist Watch
Heart rate zones
- HR max ;
Feb 20, 2009 | Garmin Forerunner 50
Polar f11
no it shouldnt be cause the heart rate would be based off your pulse
im not a heart specialist but ive had my share of heart polups and a faulty valve in my heart
i was told by my doctor that the heart rate is monitored by bloodpreasure threw the veins pulse so i dont think that the size of the watch would make a difference this is in my opinion based off my own docs words hes the doc what can i say
but recommend that you speak with your doctor about heart monitor watches they know more indepth about these devices or your local pharmacy
i hope this helped you out
Jun 05, 2008 | Polar F6 Wrist Watch
Watches Logo
14 people viewed this question
Top The Watches Experts
D. E. Hev
John mullen
vince
Are you a The Watch Expert? Answer questions, earn points and help others
