Question about Ovens
F7 error code Pel ac - Ovens
GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Nov 10, 2011 | Ovens
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
F7 dC
Well first of all you determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
This error code F7 means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC)......
Post comments for more help or information........
Good Luck!!
Mar 26, 2010 | GE Ovens
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
Error code F7
your problem is with the EOC (Electronic oven control) or touch pad if it is seperate from the control...if the touch pad is seperate...unplug range - access the control panel - remove the wiring/tape wire from touchpad to EOC...plug range back in...leave over night...if f7 code comes back it's the EOC...if the error code clears it's the touchpad...replace the part with the problem...if touchpad built into EOC replace the EOC. Hope this helps...if you have any other questions please feel free to comment again.
Jul 06, 2009 | GE Ovens
Giving an F7 error code
There was a tag on stove that told on the error codes. Reset pad, it was somehow stuck. Thank you for your help!!
Cheryl
May 27, 2009 | GE JRP15 Electric Single Oven
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Oven shows F7 error problem with irritating beeping sound
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Range led flash code F7
Here is the error information for Fault Code F7
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Hope this is helpful, I will also provide you a link to to a helpful site.
http://www.applianceaid.com/fault_codes.html
Mar 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
