Question about Acer Computers & Internet
Acer monitor v193hqv power supply regulater ic burn so iwant circuit or ic no part no ic 802
  • 244 Answers
SOURCE: the power supply don't operates - INFOCUS X1
Usually the projector bulb, try to replace it first but I will not recommend you to do so but it is your decision.
Posted on Nov 21, 2007
projdoc
  • 2237 Answers
SOURCE: InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Posted on Jul 17, 2009
  • 5603 Answers
SOURCE: pmp3000 problem power supply.ic circuit problem
I have a PMP5000 that I had to resurect. I had to trace out the power supply to repair it.
I can give you hint: First, a small supply runs directely from the line and generates some of the small voltages. While this starts, the main power caps are charged through limiting resistors. The main switcher is brought online and if the power amps acheive balance, then a relay connects the speakers and shorts the limiting resistors.
This is what is in the 5000 and I suspect the 3000 is similar.
In my 5000, there was arcing at one side of the power amps. The board was burned and three power fets fried. Cancer of burned board had to be carved out and traces replaced by hardwiring.
In addition, the limiting resistors were blown open, both main switching transistors were blown and 4 small driver transistors (surface mounted) and several diodes AND a switching regulator chip (surface mounted).all fried/
Hint: When restarting the unit, put a 150 watt light in series with one of side of the power input to limit the current in case you did not get all the dead bodies out.
This is a class "D" amp which drives PCM waves into a filter which is then the audio output. It is much more efficient thaan a linear amp.
Posted on Dec 25, 2009
andik_guru
  • 146 Answers
SOURCE: Tick tick sound appear from
the sound you heard come from power regulator. its just fine, just indicate that part are over heat.
maybe you ill consider replace your monitor with LCD. more friendly for your eye and less power consumption
Posted on Mar 08, 2011
  • 381 Answers
SOURCE: i do't have driver for acer V193HQV lcd
YOU dont need drivers for a lcd screen, just lug it and it will work
Posted on Oct 26, 2011
I NEED E59670 POWER SUPPLY IC 802 PART NO WANTED
Your best bet is a universal power supply. Cheap and readily available.
Feb 18, 2015 | Acer Computers & Internet
Ic number of acer lcd monitor v193hqv?
Hi guys the pwm ic number in acer v193hqv is TEA 1530 AP.......
Aug 05, 2014 | Acer Computers & Internet
Acer v193hqv lcd
and it will not the is no driver for help you with that like the lcd compatible upto 1024x768 60hz-70hz can't display more than that resolution and frequency
Jan 12, 2014 | Computers & Internet
Monitor acer v193hqv
WHAT IS THE PROBLEM ? .
Jun 12, 2013 | Acer Computers & Internet
Acer flat screen monitor
acer monitor v193hqv power supply regulater ic burn so iwant circuit or ic no part no ic 802 problem plse solution
May 03, 2013 | Acer S202HL LCD Monitor
SIR, WILL YOU PLEASE LET ME KNOW THE NUMBER OF THE IC802 IN THE POWER SUPPLY,BECAUSE THE EXISTING IC 802 BURNED BEYOND RECOGNIZE
Unfortunately not. If you are talking about what i think you are talking about, then you will not be able to find that number if it is burned away. That number is either a unique production batch number or a manufacturing date, either way, if it is burned beyond recognition, then unfortunately, that number is forever lost. If you are searching for a replacement chip, however, i have found one online; you can use this link http://www.donberg.ie/catalogue/semiconductors/semiconductors_tda/tda_16846.html
Feb 16, 2011 | LG Flatron L1718S LCD Monitor
Computers & Internet Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
