Question about Canon Office Equipment & Supplies
Cricut print and cut opens my print window, but once I hit ok, nothing happens. For the record, I can print other things just fine, including things from the web. Using Canon xI6500
SOURCE: Canon DC230, DVD-R: Won't initialize or finalize
Try the Canon DVD-RW I have had no problems. Any other discs will NOT work, Sony, Memorex, Fugi etc
Posted on Mar 17, 2009
SOURCE: cricut wont cut
My wife's Cricut recently developed the same problem. I work on computers and mechanical stuff, and figured it couldn't hurt to open the machine for a look. What was happening was that the solenoid (like an electromagnet) that pulls the blade down into the paper has stopped working. I don't know if the solenoid itself has gone bad, or if one of the two wires leading to it has fatigued and broken. Whatever the case, my wife called ProvoCraft, and the rep told her it wasn't repairable and she'd have to buy a new one. Personally, I'd like to try and fix it first...
Posted on Jun 26, 2009
  • 9 Answers
SOURCE: need to update firm ware on cricut expression so i can use sure cuts alot could not find at
Go to
and use torrent to download the program
Use it to update any driver
Posted on Jul 05, 2009
  • 3 Answers
SOURCE: Selphy 510 won't print from computer, print ok from camera ...
Did you download and install the proper Vista driver from Canon's website? If not, I would suggest that. If you have, then try opening the device manager and look for the printer. Reinstall the driver and just direct it to look in the proper folder for it.
Posted on Aug 12, 2009
SOURCE: I hit the record button and nothing happens. I
I did nothing to it .Went to the video club the next day and it worked.
Posted on Aug 20, 2009
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    When using a design in Cricut Craft Room, and select cut, my Expression 2 begins, but does not complete, the cut. The arm moves to the paper and then makes a croaking sound and then nothing.
    Search for support faq go to expression 2 search format and reset. Watch the video on format and reset and do as it says. Calibrate when it's finished. If this doesn't work re download ccr after deleting it from your computer.
    Jan 10, 2016 | Provo Craft Cricut Expression 2 Electronic...
    Cricut explore one. Downloaded program,but get error message,wont install
    Frustrated!!! [Driver installation problems][Resolved] - Make The ...
    May 11, 2010 - 29 posts - ‎10 authors
    I cannot get the Cricut firmaware to update. ... I just got a new computer with Windows 7, I tried to cut with the cricut but I get two error messages. RESOLVED Problem getting computer to recognize Cricut
    Dec 15, 2010
    RESOLVED!!!Help Sending Cuts to Cricut
    Jul 24, 2010
    Cricut Error: Unable to load drivers
    Jan 28, 2010
    cannot get program to cut
    Jan 14, 2010
    More results from
    Dec 28, 2015 | Computers & Internet
    I have the original Cricut and have never had a problem. Now it won't cut. Nothing happens when I hit the Cut button. Is there a way to fix it?
    Hi you could try's phoning cricut. It's free to the states. The number is on the website. You may have to wait on hold for a while but they will answer and you will definitely get an answer.
    Feb 28, 2015 | Provo Craft Cricut Expression Personal...
    My cricut wont turn on
    Hi, My cricut expression is more then 5 years old. I used it one day and the next day I would not come on (it dose Nothing at all). I brought a new power cord from cricut and still nothing. I'm unable to buy a new one Please help if you can. Thanks!!
    Jan 26, 2014 | Cricut Expression Cutting Machine
    Cricut mini flashing red light
    1-Open Cricut Craft Room with circuit on and flashing green/red
    2-Hold power & feed button together until both are solid green
    3-You'll be prompted to update firmware
    4-Press & hold two buttons again (keep holding)
    5-initiate firmware update
    6-Let sequence go until 99% may hear a sequence of beeping, don't be alarmed
    7-Release buttons
    8-You'll be prompted to restart your machine
    9-Unplug all plugs from Cricut
    10-Wait 30 seconds
    11-Plug in both cords
    12-Power on Cricut
    13-Light should be solid green
    14-Press OK on Craftroom prompt on computer
    Jan 03, 2014 | Provo Craft Cricut Disney Font Cartridge
    My cricut expression keeps turning on and off. Resetting does nothing since it won't stay off or on long enough to actually reset. Any ideas?
    I would contact cricut because you may have a defective machine. I had an expression and cut one thing then it froze. We did the reset and that did not resolve the issue. Cricut had me send my machine back and they shipped a new one. Mind you they will put a charge on your credit card only to protect themselves. You just ship yours to them the way they tell you in the one you receive. Let me know if you do not have their contact number.
    Feb 16, 2010 | Provo Craft Cricut Disney Font Cartridge
    Print spooler not running windows xp this has just happened, working fine prior, put on acrobat editor soft ware then problem flaged, removed software but problem remains. Reinstall printer software...
    Ok this is an easy one..
    Click "Start"
    Step 2 Click "Run"
    Step 3 Type in "services.msc"
    Step 4 Click OK
    Step 5 Find Print Spooler in the list of services
    Step6 Click "Start"
    Step 7 Check "Automatic start"
    You are done.
    Feb 09, 2010 | Epson Stylus Photo R340 InkJet Printer
    I just opened the box from a TV ad purchase of the cricut. When I turn it on the carrier moves to the right and makes a horrible noise. Nothing will work.
    Yes, the carriage does move to the right and it makes a funny noise as it moves. The cricut then should light up with display and power light. If yours is not then I would contact Cricut as you may have a defective machine. Just know they will put a charge on your card to ship another machine to you and will remove the charge when you ship your machine with issues back to them.
    Dec 27, 2009 | Provo Craft Cricut Disney Font Cartridge
    Cricut not cutting anymore
    I was reading lots of forums and tech support pages on how to get my Cricut back online. I went to the store and got the Deep Cutting Blade & Housing and I got two replacement blades for the original housing that came with the Cricut. I also bought a pack of new mats. I replaced the original blade with a new one, used a new mat, and tweaked the depth and speed of my cuts and my little Cricut is whirling again!
    Jun 25, 2009 | Provo Craft Cricut Disney Font Cartridge
    27 people viewed this question
    old marine
    old marine
