Question about Invacare Health & Beauty
Invacare flashes 6 times on my m51 wheel chair.
  • Invacare Master
  • 1,055 Answers
Hi flash 6 times is a right park brake fault .,.contact invacare dealer., cheers
Posted on May 03, 2017
Invacare Pronto M51 lights on controller blink 2 green 1 red
It means the battery voltage has dropped below the operating range of the chair electronics. Either need new batteries or maybe a charger and new batteries. There is always a chance of loose battery harness connections.
Jan 12, 2018 | Invacare Health & Beauty
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
How do I reprogram my invacare pronto m51power chair
You will need to contact a service tech in your area to do this. They should have a special programmer box that can adjust the settings on the chair to improve the chairs performance.
May 02, 2015 | Invacare Pronto M51 Power Wheelchair
When I turn my wheelchair on a service indicator light at bottom of joystick blinks 9 times. How do I fix this?
If: Battery indicator flashes the charge level is low
immediately after recharging.
Then it is a. Weak Batteries.
b. Charger malfunction.
c. Electrical malfunction
Solution a.Replace batteries.
b. Replace charger. Contact Dealer/Invacare.
c. Contact Dealer/Invacare.
I got the above from the manual. The link is:
Jun 13, 2014 | Invacare Pronto M51 Power Wheelchair
I have a pronto m51 wheel chair got the joy stick wet it flashes 7 times how can i fixs it
Here's your M51 manual:
Trouble codes start at p25.
Also, Invacare is proud of the M51's wet-weather performance (check the "Rain Test" chapter in the manual. You might have a warranty issue. Check with an Invacare dealer.
May 06, 2014 | Jet 3 Ultra Power Chair
How to move dead electric wheel chair
There are two levers, one for each motor, you have two. Depending on model either right under your knees (M51) usually, or under the rear, near the back casters. Typically black rubber on a metal rod. Move both in opposite directions, either both out, both in, or some types, both up, or both down. Sometimes they need wiggling, turn the chair OFF then try moving it in each position, (both in or both out). Google the manufacturer, your case invacare, they have detailed instructions there.
Jul 08, 2012 | Invacare Pronto M51 Power Wheelchair
Sure step m51 lights flashing
The year info is the 1st 2 digits of the serial number. The S/N is located on a Mfg's sticker afixed to the frame of the chair.
Are you sure it's in gear?
Sep 03, 2009 | Invacare Supply Group Invacare Pronto M51...
Health & Beauty Logo
29 people viewed this question
Top Invacare Health & Beauty Experts
Colin Taylor
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
