Question about Coffee Makers & Espresso Machines
My coffee machine isn't making boiling hot coffee
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 45 Answers
It may be time for a new coffee machine.
Posted on May 03, 2017
Not hot enough
There is a setting between "Warm, Normal, Hot and Extra Hot" however no espresso machine will "boil" the coffee, as this would burn the coffee and taste disgusting.. The best thing to do is to zap the coffee for a little while in the microwave if you like a scalding cup of coffee..
May 14, 2014 | DeLonghi EAM3500 Espresso Machine/Coffee...
Water not hot enough
Set the temperature to "extra hot" If still not hot enough, try zapping your coffee for a few moments in the microwave.. no coffee machine will boil the coffee as this would burn and cause an awful burned coffee taste
Apr 19, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Keurig problems
Hi Vera
in my experience there are two types of coffee machines of this kind.
One boils the water in the spout that transfers the water from the water holder to the coffeepot
The other type boils the all the water in the tank before it run through the coffee. The latter type usually makes hotter coffee.
all the best
Kolbrun
Mar 07, 2014 | Coffee Makers & Espresso Machines
How to prime
I have NO idea what coffee maker you have but most do NOT have to be primed. Just put put water iun the top resevoir, coffee in the other and turn it on. THe water will boil and very hot water will boil up to the coffee in the coffee resevoir and through it.
Dec 31, 2012 | Coffee Makers & Espresso Machines
How do I increase water temperature on Krups KP 2100
Heat the cup before you use it, run hot water over it, or boiling water. The machine does not make very hot coffee otherwise.
Sep 22, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
How hot should fresh perked coffee be from any coffee maker?
some people say that coffee can burn when you pour boiling water on the beans and recommend that you should add the milk first... I just let the kettle cool down until the boiling stop as well. as for espresso makers, water will boil and the gas (liquid to gas at boiling temperature) is pushed through the beans, so its rather hot and the beans doesn't burn.coffee should be as hot as possible!
Apr 02, 2012 | Coffee Makers & Espresso Machines
LAVAZZA EXPRESSO POINT THE RED LIGHT BUTTON KEEPS FLASHING CONSTANLTY, WHEN I MAKE THE COFFEE IT SQUIRTS OUT ALL OVER THE PLACE, IT DOENT HAVE A NICE FLOW LIKE IT USE TO
Causes:1- the 130 deg thermostat is open. 2- working thermostat, 104 deg, defective, allowing temp to rise.3- the machine becomes hot because the water valve is stock open. machine needs to be sealed so not to allow water to boil.Water boils at 100 deg Celsius. 4- valvolino or o-rings are worn out and leaking. You need a repair shop.
Guru
Sep 21, 2011 | Lavazza Espresso Point Capsule Machine
I recently bought an Avanti Art Deco 10 cup espresso machine and am disappointed that I cannot make HOT coffee with it. What can you suggest?
When the water boils in the bottom chamber the steam creates pressure and pushes the water through the grounds and into the top chamber. It's hard to imagine that the water going through the grounds is not close to boiling temperature unless you are using the coffee maker at high altitude where the temperature of boiling water would be lower.
Oct 26, 2009 | Avanti Art Deco 4-Cup Espresso Machine
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
