How do I retrieve an item that went down the holes in the bottom of the washer: Estate ETW4300TQ0 wash machine
ngafm
  • 166 Answers
SOURCE: estate washer TAWS700E
Peace Friend,
ngafm At your service!
Things wear out! So is life!
Sounds like the coupling conecting the transmisiion to the agitater is worn out!
If I were there hands on I could be definite.
Only a hands on laundry tech can make thediagnoses.
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE
Posted on Sep 10, 2008
duby1990
  • 367 Answers
SOURCE: washer smells after load
First thing to try is to get affresh washer tablets. They are a new product from whirlpool designed for front loaders to keep the smell out. They also work great for top loading machines. They are about ten dollars a pack. Read the instructions and run the washer through its cycle and the smell get better. The longer you use it, the smell should go away.
Posted on Nov 18, 2008
JULIANFIX
  • 975 Answers
SOURCE: my estate washing machine is leaking
YOU need to replace the "CENTER SEAL" , looks like thats the problem , no need to remove MOTOR , just the inner tub inside the BIG tub , andyoull see the SEAL.
Posted on Nov 26, 2008
SOURCE: Water runnning out from bottom of washing machine
Barbarahaps,
I had a similiar problem with a Brand X washer. the problem may be your water pump. if so, it is an easy fix for someone who is mechanically inclined. you first must see where the water is leaking from. when i did this, i securly placed my washer on cinder blocks so that i could see underneath it, and let it fill with a little bit of water, then i could clearly see the water leaking out of the water pump. the key concern here is safety, make sure that the machine fills with only a little bit of water, and then cut the power off to the machine to ensure it doesn't start going through its cycle while up on the blocks, creating a potential hazard. If it is the waterpump, find a washer repair store, tell them the year and model machine you have, and get a water pump on order. the water pump is a pretty straight foward repair--you disconnect power from the machine, turn off and disconnect the water supply, disconnect the drain pipe, and tip over the washer to expose its under side. you disconnect the hoses going to the water pump, remove the attaching bolts, and install the new pump. then you hook everything back up and you should be good to go. hope this helps.
Posted on Jan 18, 2009
  • 54 Answers
SOURCE: Washer fills with water but wont continue washing cycle
Your lid switch is bad or loose.. open and close your lid and see if you can hear clicking noises.. if not.. then your lid switch is broken.. good luck
Posted on Jan 21, 2009
Estate washer just stopped at the end of the wash
sounds like a bad timer? will it do something if u turn it manually? a bad door switch can shut everything down also, if it just went out?
Oct 03, 2014 | Washing Machines
Agitates and spins with clanking noise at the same time
The brakes are not engaged and the brake assembly will need to be replaced. Here is the part to order.
Below is a video to show you how to make the repair.
Nov 13, 2012 | Washing Machines
My etw4300tq0 washer will fill up with water, then stops.
etw4300tq0
Same problem... any help out there I see this post is over a yr old... it is now dec 29, 2010 and I have the same problem.
Mar 23, 2009 | Estate ETW4400VQ Top Load Washer
Jan 21, 2009 | Washing Machines
Washer smells after load
Nov 17, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Small earrings fell into holes on bottom
if they fell through those small holes doubt you'll find them something that small would probably be pumped out and down the drain ..if you haven't used washer since may be lucky enough to find them in pump but doubt it pump is pretty strong and can handle almost anything except socks and thongs
Sep 11, 2008 | Estate TAWX700JQ Top Load Washer
NOT SPINNING- ESTATE TAWS800JQ
If it washes (agitates) check the lid switch next - thats just below the hole in the top. poke a wooden pencil in to aactivate or just remove and check switch
Regards
Jul 19, 2008 | Estate TAWS800JQ Top Load Washer
Washer leak in an estate washer
i have Had 3 estate washers leak on all four corners....there junk went with ge instead......estate washers are horrible
Mar 20, 2008 | Estate TAWX700JQ Top Load Washer
Estate TAWS900JQ2 will not agitate or spin or drain
Most likely it is your top door safety switch, this switch is enguaged by a small plastic rod on the bottom of the top load door which goes thru a small hole on the top of the barrel shield, which inturn depresses a switch. Make sure that the switch is working propperly.
Dec 16, 2007 | Estate TAWS800JQ Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
