Question about GPS
Does Tom Tom sell historic goldmine maps to upload
2 Suggested Answers
  • 13433 Answers
SOURCE: tom tom activation for nav 5 map of france plus
are you able to get the activation code from the website I linked you to?
You may have to contact tomtom direcly about the code issue, copy protection.. Only they can provide you with the correct code.
Posted on Aug 09, 2008
I want to download updated maps.
we at fixya dont sell updates sign into your units manufacturer -tom tom / garmin etc and order update
Sep 06, 2016 | GPS
Hello Im wanting to upgrade my maps on my tom tom please
Visit the Tom Tom website & download the updates to PCs or laptop then upload to Tom Tom, there may be a charge for this service
Dec 04, 2015 | GPS
How do I update my maps on my Tom Tom
plug into your computer and download the update. Your program on the PC will upload for you to the TT. You need to get the free system updates too from TT while you are at it.
Jan 03, 2015 | Tomtom TOM TOM ONE WE V3 GPS Receiver
Harley trouble codes
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
Why there is no gps device in the tom tom?
If you referring to the map, there are many reason for this to take place, you removed the map when uploading, you disconnected the usb while uploading, there are many factors.
Jun 23, 2011 | Tomtom ONE GPS Receiver
JUST GOT NEW TOMTOMXL AM I SUPPOSE TO INSTALL SOMETHING MY NEW TOMTOM DIDNT COME W ANY INSTRUCTIONS CANT GET FURTHER THEN SETTIN UP ICONS & SETTN MY HOME ADDRESS I NEED TO B ABLE TO PUNCH N...
You need to go to the tom tom website to register your tom tom, then you upload maps, some do not have the operating software on them so you will have to install the operating software on it also, then upload your maps too. After doing this, you will be able to connect your gps in the car and it will work.
Dec 28, 2010 | Tomtom GPS
NEED UPDATED MAPS
Hi Some Sunday Markets Sell disks with maps for all types of GPS units try there.
May 10, 2010 | Tomtom ONE GPS Receiver
Can i get free map up dates for my tom tom go 910
You can get free shared updates from the users when you install the Tom Tom Home Software, but to update the map with the TomTom approved information, you will have to pay, unfortunately. So far, the people-uploaded maps have helped me immensely, though.
Sep 25, 2009 | Tomtom GO 910 GPS Receiver
Kep geting message hard drive is full cannot upload
You will have to delete some features, icons, or voices from your tom tom using the desktop software on your PC in order to upload a new map to it.
Mar 17, 2009 | Tomtom ONE GPS Receiver
Tom tom activation for nav 5 map of france plus
Aug 09, 2008 | Apple iPhone 3G
GPS Logo
23 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
