Question about HP Office Equipment & Supplies
How do i clear scanner error on printer HP M121 NFW MFP to enable the use of fax?
manojro
  • 495 Answers
SOURCE: Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
Posted on Apr 17, 2009
haivanko
  • 37 Answers
SOURCE: error 6 hp laserjet 1120 mfp
The problem is that the motor that drives the scanner probably overheated and because of the cheap plastic that HP used it melted important points that the motor relis on...so - remove the glas of the scanner(there are some screws - one of them hidden under the label of the panel,unhook the interface cable of the panel).Now you should see the scanner - flip it over and look at the motor exle and the gear that it should mesh with - they are not aligned at this time.To fix it i used 2 small pieces of plastic - sticked it under the motor so that it can not move in vertical direction anymore. Simply this is the solution that i used and it works just fine :) If you have any questions dont hesitate to contact me. alpescomputers@winetbg.com
Posted on Jun 15, 2009
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Posted on Apr 19, 2010
  • 8 Answers
SOURCE: Printer Model : HP Laser
indicate that the scanner unit are error.reseat the flexible cable in the scanner unit.
Posted on Nov 23, 2010
SOURCE: SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Posted on Feb 04, 2011
How can I repair laser scanner HP m 500/525 mfp?Every time when it shows the error code,I try to calibrate the scanner and shows black vertical lines.
this is very difficult to solve from your location. I will give you tech support ,please send me your email address or add me your skype xptareq2000@msn.com
Aug 20, 2016 | HP LaserJet Enterprise 500 M525f MFP -...
I have hp pro 400 always give me scanner error 6 and there is a sound inside the scanner please give me help??
Scanners should not have "sounds" inside so my wild guess is that something is broken and you should call to a repaiir resvide to get a diagnosis.
Oct 22, 2015 | HP LaserJet Pro 400 color MFP M475dw -...
HP 1217 M1217 nfw MFP won't receive fax
Having the TAM set to four rings seems a bit high to me. Decrease the ring count on the Tam. the fax ring count does not really matter.
Keep your outgoing message to a minimum . if too long the calling machine will time out and drop off the line.
see how that goes. Also are you using the genuine adaptor lead. Does the tam actually ring? I suspect not. there are literally loads of adaptor leads that will fit and look the same but they are wired internally for that make only.
Jan 25, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Hp laser jet m1536dnf MFP won't send fax comm error 388
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
Aug 14, 2012 | HP PSC 2410 All-In-One InkJet Printer
843.00 service san
Restart the printer and check whether the error re-appears.
If the error did not clear, set the printer to Invalid Engine Code Status.
To do this, turn off the printer and press and hold the 3+4+6 (E+N+G) buttons while Powering the printer ON.
Update the printer's firmware with the latest level.
Jun 11, 2012 | Lexmark X658dtfe MFP - multifunction fax...
Scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Feb 22, 2009 | HP LaserJet M1120 MFP All-In-One Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
