Question about Samsung Refrigerators
HI i have samsung refrigerator Model SR419MSS, its has some problem, upper part freezer is working but lower part is not cooling. please advise for repair
SparkGap
  • 363 Answers
SOURCE: Samsung RS2577BB Refrigerator/Freezer Will not Cool
Chances are you need to get the refrigerant recharged. This can only really be done by a professional due to the equipment needed. He will also find where the gas is leaking from.
Posted on Oct 13, 2007
rayname
  • 70 Answers
SOURCE: Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
I replaced my evaporator fan behind panel in freezer this was not spinning had to remove ice maker and panel to access got parts list emailed from kitchen aid and picked up part at local appliance dealer
Posted on Jan 03, 2009
  • 31 Answers
SOURCE: Kenmore Elite model 73503201- FRIDGE DOES NOT COOL, FREEZER WORKS
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
  • 46 Answers
SOURCE: 2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
Posted on Aug 01, 2009
rickead1
  • 1998 Answers
SOURCE: samsung refrigerator RS264absh Freezer not cooling
I would check three things in your freezer seeing how your getting ice the t-stat ,the heater,and the fan these are the first things you check with ice build in freezer your freezer is what actually produces the cold the air from the freezer travels through small vents into your refrigerator sounds like a definite defrost probelm in your freezer
Posted on Apr 29, 2010
My samsung will run fine for about 4 hours and then will get too cold. if i unplug it and then plug it back in it will then work fine for another 4 hours. please advise thank you
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Feb 14, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Upper part of fig. is not cooling, freezer is working great.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 15, 2010 | Samsung 18.8 Cu. Ft. Bottom-Mount...
Refrigerator is not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 25, 2010 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
