Question about Fuji Office Equipment & Supplies
Adc sensor error / error 092-651 Fuji docu print cp205w
3 Suggested Answers
  • 92 Answers
SOURCE: My Xerox 6280 is getting an ADC Sensor Error
Hi ....
There could be 2 solutions for this problem ...
1) Switch off the device ... wait for 10 seconds and then switch it back on ... most of the time it resolve the problem ..
2) If this does not resolve the problem, you need to remove and re-install the transfer unit which will resolve the problem for sure ...
Follow the below steps to remove and re-install the transfer unit.
CAUTION: Be careful not to touch the black Transfer Belt when replacing the unit. Handle the Transfer Unit by the release latches and the tabs on the left and right side of the unit.
  1. Power OFF the printer using the power switch located on the right side of the printer, toward the back. Press the power switch to the (O) position.
  2. Disconnect the power cord.
  3. Press the button on the top, right side of the printer to open the Front Cover.
  4. Grasp and squeeze the green release latches located on the left and right side of the Transfer Unit. Rotate the transfer unit up until the notch on the shaft is aligned with the mounting bracket cutout.
  5. Pull up on the right side of the unit to free it from the bracket, and then slide the unit to the right to remove it from the machine.
  6. Hold the unit by the release latches and insert the left shaft into the left mounting bracket.
  7. Slide the unit to the left while rotating the unit to align the shaft-notch with the right mounting bracket cutout, and then press down until the shaft fully seats into the bracket.
  8. Gently rotate the unit down until the release latches snap into place. Do not push on or touch the black belt.
  9. Close the Front Cover.
  10. Connect the power cord, and then power ON the printer. A 'Ready to Print' message will be displayed on the Display Screen.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
  • 2632 Answers
SOURCE: There is an "ADC
Welcome to Fixya. ADC Slope Error Cycle Power means that The temperature slope for ADC (Analog to DigitalConverter) detects the value out of the normal range. This is a Service Call Error of CLP-610ND
Solution: This problem can be fixed by just Power Cycle. However, if the problem persists, contact the service representatives.
You can also refer to the user manual below.
Samsung CLP-610ND User Manual
Thanks for using Fixya.
Posted on May 19, 2011
Fuji Xerox Docuprint cp205w won't print in Ubuntu 13.10
try in "my computer" the added devise setting usually at the bottom of the computer bit seek the instillation method what sort of computer do you have
Nov 21, 2013 | Office Equipment & Supplies
Xerox workcentre 6015 092-651 error
That error indicates a bad ADC sensor. Try cleaning the adc sensor which is on the rear of the transfer belt. If that doesn't work, replace transfer belt as sensor is not sold separately.
Sep 18, 2013 | Xerox WORKCENTRE 6015/Ni Color
Adc sensor error
adc sensor error / error 092-651 .....docu print cp205....please help me...i cant find the solution....
Jan 21, 2013 | Xerox FUJI DOCUPRINT CP205 COLOR LASER...
Dowonlod docu print c1110b
You can download the Xerox printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-
Dec 20, 2011 | Fuji Office Equipment & Supplies
Service req e547
I can tell you that a Engine Service Error Code #E526, stands for a "SOILED ADC SENSOR". ADC stands for "Automatic Density Control" [sensor]. Hopefully, you will have your printers "User's Manual/Owner's Manual" and it will show you exactly where that ADC Sensor is located, because I do not know. I think its a removable board, that probably slides in and out, somewhere near the upper right section on the inside of the front of the printer. If you use the round knob [on the inside of the printer, near the center] as the center of a clock, then I would guess that the sensor board assembly would be around the one-o-clock to the two-o-clock position, but really don't know for sure...Basically if there are any parts of wrong specifications used, improper mounting, damage, distortion, dirt, or adherence of any foreign material, that can cause that particular error code. Hopefully the ADC Sensor is just dirty and needs cleaned. The major parts that need to be checked, are the "ADC Sensor Assembly", the "Main Harness Assembly" and the "MCU Printed Circuit Board". E532 error means there's a drain on one of the several motors within the printer. Reseat all the consumables within printer (especially the waste toner)and the paper tray the error clears. If the error doesn't clear then you have a real hardware fault and the job of changing each motor until you get the right one. This particular printer has a problem with waste toner. The toner seems to clog up and be the main cause of this error - you may find this occurs after the printer has been sat idle for sometime i.e. after a weekend. Once this particular printer starts giving this message its best to run through this routine each morning... open the front cover, unlock the two lockovers, pull out the consuambles about half way and then slam them back in - hard enough to loosen the toner but not hard enough to break the printer. Switch it on and it should remain error free all day.
May 27, 2010 | Epson Aculaser C1100 Printer
178 people viewed this question
Top Fuji Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
