Question about Cameras
My lens moves in and out when I am trying to take a picture even though it shows the batteries are charged. And it isn't because I have accidentally pushed the slide to close the camera.
    Brigadier General:
  • 4,090 Answers
It is possible that it is trying to focus on something that is closer than what you are aiming at and cannot do it. Check that there is not some hair or dirt on the lens or that you have it on macro.
Posted on Jul 25, 2009
I cant charge the battery through computer
The C183 isn't a battery charger. If you use rechargeable AA batteries in it, you must charge the batteries outside the camera using a separate battery charger.
Aug 01, 2012 | Kodak C183 Digital Camera
My Canon 5D mkI turns on ok, will focus, displays top and back, but it will not take a shot. I have two batteries, both which I have charged to full and tried (display shows full charge). I have also...
hicould you tell me the amount of shot number when you put memory card in? If yes, please move to manual position from auto on the side of lens. And try to press release button.there is other one thing you have to chack selftime release working or not. just let me know.
Jun 04, 2011 | Canon EOS-5D Digital Camera
My camera was working completely fine and then after taking a picture it just went black, lens out and not moving. so i plugged it into my computer, thinking maybe it needed to be charged, but got nothing....
Since this camera is fairly new, it may be worth your while to go to the http://www.nikon.com website and call the support repairs department. Even if the camera is not under warranty, you may be able to get repairs for little or nothing.
This may depend on if it is a common problem.
Before you call, make sure the battery is either new or charged fully.
If the camera has been dropped, accidentally got water inside, or other damage in most cases will void all kinds of warranties.
If the camera simply stopped working with full charge or new batteries, then you indeed should call Nikon.
Sep 11, 2010 | Nikon Coolpix S4000 Digital Camera
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
Nikon d80 shows err message. still after full reset it wont work
Check if your battery is charged. Are there any error messages? Otherwise, if your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
Sep 17, 2009 | Nikon D80 Digital Camera with 18-135mm...
Camera does not react
I quote: "A couple of days ago after using it when trying to see the pictures on the camera the LCD did not show anything. The lens reacted and even take pictures but nothing was visible on the LCD screen."
That means that there was a problem either with a LCD display or with ribbon cable.
Now:"I tried charging the battery and removing it from the camera, now the camera only does a bit sound when switching on but nothing else, the lens does not even come out."
That means that the ribbon cable had probably shorted, now the camera may be furtherly damaged.
The camera must be disassembled to access the LCD and fix the problem.
The repair must be done by an experienced technician, as to access the LCD you need to remove both covers.
Jan 07, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Shooting mode shows nothing.
I just had this issue with my camera (my 15 year old son solved it for me ;-) ).
The viewfinder was active in "record" mode and the LCD was "active" because you could see a little back light but no image. The "playback" mode would let me review pictures in the LCD though so I know it is capable of showing information.
If you push the display key/button a couple of times you can see the picture move from the viewfinder to the LCD and have just a picture and or a picture and information.
So try setting the camera to "record" mode (lens comes out) and then push the "display button" which is on the back of the camera just to the right of the LCD on the lower right side several times and see if the LCD starts to work.
It could be that somehow the display button was pushed by mistake.
Bill
Dec 07, 2008 | Canon PowerShot S3 IS Digital Camera
Dropped my camera.
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jul 22, 2008 | Canon PowerShot A85 Digital Camera
I dropped my camera & the lens wont shut & now I cant see any pictures
You might have changed the batteries, but have you fully charged them? That's the recommended resolution from Sony
Jul 28, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
