Question about Cell Phones
Forgot my voicemail passcode - Cell Phones
When I check voice mails asking for password . I have forgotten password how do i reset please
Depending on if you use the Instant voicemail app or call into the direct line their are different reset procedures. Additionally it will depend on the specific carrier you use. I will include some common carriers so you can use which one is applicable.
Verizon
Press *611 then press SEND (airtime is free). Alternatively, call (800) 922-0204 (toll free) from any phone to reach the automated customer service menu. Listen to the instructions then when prompted, press 4. Listen to the instructions then when prompted say "Reset voicemail password".
AT&T
Call the AT&T automated system from your mobile device. Press "1" to confirm your wireless phone number. Press "3" to select Reset Your Voicemail Password. You will receive a temporary password via free text message.
Sprint
To reset your voicemail passcode:
Sign in to My Sprint with your username and password.
Click the My preferences tab.
Under Things I can manage online, click Change voicemail passcode. The Reset Voicemail Passcode window will open.
Dec 08, 2015 | Cell Phones
How do i get a voicemail passcode when i forgot it?
This is controlled by your voice mail system administrator. Their escalated administrative privileges should allow them to reset your password. Hope this helps.
Jun 04, 2014 | Mitel Superset 4025 Corded Phone...
How to check voicemail messages
I assume you mean voicemail messages taken by voicemail service on your telephone line, the ones indicated by a flashing "voicemail" indicator on the phone. You may need to contact your service provider as not all systems are the same, but here's how it usually works. From your home phone, dial your own number so that the voicemail answers. Press the "*" button and you'll be prompted to enter your passcode. (The default passcode is usually the last 4 digits of your phone number, and you enter a new one when you go through mailbox setup.) Once you've entered the passcode and are in the voicemail system, voice prompts guide you through how to access messages and make setup changes. To process is usually the same to check your messages when you're away, although some service providers may give you a different access number to call. Again, check with your service provider for all the details if your system is different.
Sep 14, 2011 | Vtech 5.8GHz Analog Cordless Phone
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Dec 07, 2010 | Mitel Superset 4025 Corded Phone...
I have an old MITEL 4025 in my new office. Noone seems to know how to set up the message/ voicemail option. I need step by step directions. Thank You.
You need to know the Voicemail access code... I generally set this up as 77, but other installers will set it with a different number. This will be the same number that others in your office dials to reach Voicemail when they have a message.
Your mailbox will also need to be created in the Voicemail system. When you call into it, it should recognize you and prompt you for a passcode. The Mitel Embedded Voicemail system default passcode is 1111. You will be prompted to set up the mailbox and change the passcode.
If this doesn't help, contact your site administrator or vendor.
Sep 21, 2010 | Mitel 5220 IP Phone
How do I set up voicemail on a mitel 5212 IP Phone
Assuming you have the Embedded Voicemail... dial the Voicemail access number... it should recognize your extension number and prompt for a passcode - the default is 1111. Follow the prompts to set it up.
If the mailbox is already set up from a previous user, have your administrator reset it.
Sep 14, 2010 | Mitel 5212 IP Phone
Samsung DCS Basic 12B phone voicemail
I assume you forgot the passcode to a voicemail box , not the pass code to the voice mail system. The easiest way to fix your problem is to enter voice mail programming(from a telephone) and delete the box and then create the same box again. That way the mailbox when created will come up with the system default pass code
Sep 10, 2008 | Samsung DCS 12 Corded Phone
Nokia 1600 - Key #1 Voicemail
go to setting>restore factory setting>enter 12345
now restart phone
preess and hold 1.
enter the no of Voicemailbox
Feb 16, 2008 | Nokia 1600 Cellular Phone
Voicemail passcode
Both of these problems can be cured by calling a tracfone operator. You will not loose the recorded vioce mails that way.
Dec 12, 2007 | Motorola Mobility TracFone C139-4 Cellular...
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
