Question about Dishwashers
Dishwasher always trys to drain and won't wash. it seems that the computer needs to be reset. How can i reset the dishwasher??? SIMPSON RIVIERA 966
  • 98 Answers
If it is a bosch, see my guide here on drainage issues. While there is a massive recall on the control boards, I doubt it is really your problem. Most likely a plug in the drainage system.
Posted on Jul 26, 2009
Simpson agitator
I have the same problem, seems as if this washer always tangles the clothes, there is really no solution.
Aug 25, 2014 | Simpson Washing Machines
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Water won't go down drain.
It appears that you have a drain pipe problem. Check that the hose is not restricted ( kinks etc) Get a good drain cleaner that you can use in you machine and clear the gunk out of the hose. Contact simpson dealer for a compatible product to do the job as some drain cleaners react with the steel and hoses.
May 06, 2013 | Dishwashers
Drain pump always running even after a reset
So you need to replace this flood sensor. i am thinking it is in the bottom of the machine and senses the a high water level in the wash tank beneath the wash arm.
Google
make model spares
you will end up at a site like this. Look for the part and replace it. I used 'Bosch dishwasher flood sensor' as the search query.
dishwasher Google Search
Mar 29, 2017 | Dishwashers
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
My Simpson Riviera 966 wont complete wash cycle,whats wrong with it ?
1) timer- it stays wherever you leave it and does that action.
2) No fill -cold- for rinse
3) No pump out
4) Syphoning- where is your drain hose ?
5) Set to " no spin" drip dry" -- reset control
6) Lid switch - not engaging
Sep 12, 2009 | Dishwashers
Simpson 860 dishwasher. Ticking but not washing. Does it need to be reset? Where is the reset button ?
Program choices can be reset by holding in the program button which is on for 10 secs and the reselecting the program you want.
Apr 12, 2009 | Dishwashers
Simpson dishwasher intermitantly does not wash properly, i think it doesnt always fill correctly
Make sure the filters are clean and that the spray arms do not have food particles blocking the outlet holes. Always a good idea to rinse these off plates before they go into the dishwasher.
Aug 10, 2008 | Dishwashers
Dishwashers Logo
265 people viewed this question
Top Dishwashers Experts
