Question about Bosch Refrigerators
Where is the control panel for the bosch frost free 44?
5 Suggested Answers
  • 3 Answers
SOURCE: Bosch intelligent frost free 44
there is a drain hole in the freezer dept in the fridge that is blocked This requires removing all the panels etc within the freezer until you get to the main grill at the back This will be iced up so you might have to wait a while or you might be able to chip away at it. You will then see the drain hole concerned at thre bottom Try pocking a thin wire down it or poor hot water over it Its a bit of fiddling around but is not hard to clear Problem solved
Posted on Feb 28, 2009
imufo2
  • 3773 Answers
SOURCE: Bosch Intelligent Frost Free 44.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 08, 2011
  • 51277 Answers
SOURCE: I have a Bosch Intelligent frost Free 44. It keeps on switching on and off the whole time but when I leave open one of the doors, it runs normally. What could the problem be?
faulty thermostat
the thermostat presets on on/off temperature is faulty and when the door is close it is cycling but when the door is open the cycle is not allowed to happen because the on tremp is engaged full time
get a technician in to properly diagnose the fault and quote .
Posted on Aug 31, 2016
  • 595 Answers
SOURCE: On the bosch Intelligent frost free 44, if I want to check on the gas, who many gm gas do I put in. If the compressor doesn't put off, what can be wrong.
Gas in fridges and feezers are expensive to refill, if the unit is more than a few years old may be better to replace, if less than 12 months old should contact seller under warrenty.
Posted on Feb 27, 2017
Feb 27, 2017 | Bosch Refrigerators
faulty thermostat
Aug 30, 2016 | Bosch Refrigerators
Intelligent 44 frost free. Why is the compressor not starting up?
The thermostat controls when the compressor switches on ,it does not nun all the time only when the temp rises, if the thermostat is ok and the refrigerator is hot it could be a faulty motor or compressor .
Jul 09, 2015 | Bosch Refrigerators
the fridge might have iced up in the coil due to a defrost problem. one way to check it is to leave the fridge off for a few hours and leave the door open. turn the fridge back on after the few hours and see if the performance is any better. Let me know how it goes
May 22, 2014 | Refrigerators
Bosch Intelligent Frost Free 44. Freezer on top. Water leaking at bottom of front door. What is the cause of this problem and how can it be fixed.
Leo Ponder
imufo2
Aug 07, 2011 | Bosch KSU49630 Top Freezer Refrigerator
Ice getting accumulated even it is frost free
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 07, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Feb 02, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch KGU44120 frost free fridge freezer (6 years old) generates ice on floor of freezer compartment within a couple of hours. Maintains -20C temperature no problem.
drain is blocked in freezer. take back panel off inside the freezer and you will probably find that the bottom is covered with ice. melt off with a hairdryer and hot water till water flows freely down the drain. needs a bit of patience
Jul 04, 2008 | Bosch Refrigerators
Refrigerators Logo
29 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
