Question about The Health & Beauty
Why do the seven series shaver need to have a water tank never needed one for any previous shaver I have owned
2 Suggested Answers
SOURCE: We lost the instructions on how to use this shaver
Don't know if you found the manual yet, but a link to manual is right on the fixya site:
http://www.fixya.com/support/p115840-braun_syncro_7526_electric_shaver/manual-18313
Posted on Mar 14, 2009
Why is there no red light when it is plugged in?
You probably need to replace the rechargeable batteries. The batteries work in series with the shaver... if just one is completely no good in the battery pack, the shaver won't work. NimH batteries only last 2 to 3 years at best; older NiCd batteries far less. All rechargable batteries are made by either Matshushita (Panasonic) or Energizer (old Sanyo brand and before that the GE brand). Some mfrs build their own battery packs using rechargable batteries with TABS from these battery mfrs and wire them together end to end + to -, etc, like a flashlight (torch UK) to make the proper voltage. A Norelco brand is the same as a Phillips shaver.
Apr 23, 2015 | Health & Beauty
Are electric razors hard to clean?
No usually come with brush or wash under water
Aug 16, 2014 | Panasonic Linear ES 8003 W Electric Shaver
Can batteries be replaced in the 7000 series shavers when they are no longer able to take a charge?
You can change the batteries in 7000 series shavers. You will find the correct battery type at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll down the page for installation videos
Aug 18, 2011 | Braun 7000 Series Foil and Cutterblock
How can I clean my braun washable series 3 (330) shaver. better. I can take it apart so far but just cant get under the blades
This model uses a 'shaving cassette'. The blades can not be removed from the foil assembly. Braun's instruction is to simply rense the shaving head under hot running tap water. Unfortunately, this does not work very well over time due to the poor design of these parts. Once they become clogged up it is usually necessary to replace the cartridge.
If replacement is needed you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jul 27, 2011 | Health & Beauty
Series 3 - 340, my father wants replacement foil & cutter, where can I order one from please.
Braun makes two distinctly different models, both with called seroes 3-340. You will need the type number as written on the shaver to properly identify the correct foil and cutter for his shaver. Both types are available at shaveroutlet.com. See the two links below. You will need to use the type number of his shaver to select the correct one of these two
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-foil-and-cutter-p-141.html
Jan 11, 2011 | Braun Health & Beauty
I need to buy shaving heads HQ8
philips norelco HQ8 replacement heads for electric shaver norelco spectra 8800 series, norelco 7800 series, norelco 7100 series, norelco 7200 series.
Oct 25, 2010 | Braun Replacement Foil Cutter for Most ...
I have a 7 year old danby portable air conditioner it seems to work good but my neighbor just purchased a new 12000 mine is 10000 he said he has to empy water frequently We have never had a drop of water...
This model is designed to heat the condensed water and send it out the exhaust duct as vapour. It prevents accumulation on less humid days. It sounds like it's served you well for seven years.
However, I do recommend one step for owners of the DPAC series. At the end of the season, drain the internal tank by opening the two taps at the bottom rear. Put a pan beneath them . The internal tank only holds one cup of water.
Jul 10, 2010 | Danby DPAC120068 Air Conditioner
Trying to find how i can build my own trailer mounted sprayer for dust control
No need to re-invent the wheel when building your trailer mounted sprayer. Your local Northern tool Store, or at the address below,
http://www.northerntool.com/webapp/wcs/stores/servlet/category_6970_166839
you will find all the parts that you will need to complete your project. I have purchased several different types of sprayers, tanks, pressure pumps and parts from them over the years. They have a helpfull staff and most parts are in stock. Take a look at ready made trailer mounted sprayers there to pattern yours after then design in your special needs.
My first portable sprayer was made from four 55 gallon drums loaded onto the back of my pickup. For the pump I used a modified 2" trash/water pump reduced to 1' pipe then seven nozzles. Worked great however 220 gallons of water did not last very long. Problems began with the weight of water in large quantity. I decided I needed about 1000 gallons and found that I needed to deal with about 7500 lbs of weight. Oh well, enough already, good luck with your project and email if you have questions.
May 11, 2009 | Cam Spray 25006PM 2500 Psi Cold Water Gas...
Health & Beauty Logo
22 people viewed this question
Top The Health & Beauty Experts
garzamarissa
garzamarissa
Level 1 Expert
Christelle van der...
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
