What is this used for. CK-08 94 VO. P/N 085-6150-03. Rev.A
Who uses this device and for what type of applications
Driver for vo magic camera ipc380
use driver identifier software to freely and easily download drivers for all the device that you can plug with your pc.
use the following link.
http://driveridentifier.com/files/driveridentifier_setup.exe
Note: No payment or card is needed.
just sign up and select the non-commercial use plan and enjoy free downloading
Jul 13, 2014 | IO Magic Corporation GigaBank Computers &...
My black berry phone shows app error 523 with white screen and keeps rebooting what do i do it is giving concern
(IGNORE THE SIM STEPS IF ITS STILL ON VERIZON PLEASE)i had the same issue on my 9700!!! its either the sim or the software on the phone. DO NOT SELECT RESET YOU WILL LOSE ALL YOUR INFO!!! take out the battery with the phone on and take out your sim card. replace the battery without your sim card and see if the error still shows up. if it doesnt its your sim, super quick and easy most carriers will provide you a new one free of charge! if its does appear without your sim its the software. still fixable but not as quick. replace the sim & battery & power your phone on. you'll need a computer and the desktop manager which you can down load if you dont have it already from blackberry.com for free. then run the app loader. the storm has the blackberry 5.0 software and you want to make sure your desktop manager matches. follow the steps from http://www.blackberryforums.com.au/forums/bis-blackberry-desktop-manager/734-use-blackberry-application-loader-load-blackberry-device-software.html and you'll be set!!!
Use BlackBerry Application Loader to load BlackBerry Device Software
Doc ID : KB03621
Last Modified : 2007-05-18
Document Type : How To
Environment
  • BlackBerry® Desktop Software 3.6 and later
  • BlackBerry Device Software
  • BlackBerry device
Warning: You should not install BlackBerry Device Software that is older than the version installed on the BlackBerry device. Doing so could cause the BlackBerry device to malfunction.
Procedure
To use BlackBerry Application Loader to load BlackBerry Device Software, complete the following steps:
  1. Install the BlackBerry Device Software on your computer.
  2. Open BlackBerry Desktop Manager.
  3. Connect the BlackBerry device to the computer.
  4. If prompted, type your BlackBerry device password and click OK.
  5. Complete one of the following steps:
    • If the Application Updates Available window appears, click Update Now. The Application Loader Wizard appears.
    • If the Application Updates Available window does not appear, double-click the Application Loader icon. The Application Loader Wizard appears.
  6. Click Next.
  7. If prompted, type your BlackBerry device password and click Next. Note: When the Application Loader Wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation. The selected check boxes indicate applications that are already installed on the BlackBerry device.
  8. Select the check box for the BlackBerry Device Software.
  9. Click Next.
  10. If the On the Device Backup screen appears, choose whether to automatically back up the BlackBerry device and click Next.
  11. Click Finish to begin loading the BlackBerry Device Software.
  12. Click Close when the software is finished loading.
Dec 24, 2010 | RIM BlackBerry Storm 9530 Smartphone
They try to unluck my blackberry rim 7290 but they lock worse now i got circle and 507
Hi, Error 507 occurs when all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone. To delete all data from the BlackBerry smartphone, complete the following steps:
  1. Lock the BlackBerry smartphone, and then type an incorrect password ten times.
  2. If prompted, type blackberry.
  3. Once complete, all data on the BlackBerry smartphone is deleted.
And then you need to complete the following steps: Open BlackBerry Desktop Manager and double-click the Application Loader icon. Use the application loader tool to install the BlackBerry Device Software.
If you have typed incorrect password in the Application Loader tool, then you need to delete all data.
To delete all data and applications from the BlackBerry smartphone, complete the following steps:
  1. Connect the BlackBerry smartphone to the computer.
  2. Open BlackBerry Desktop Manager, and then double-click Application Loader.
  3. In the Application Loader Wizard window, click Next.
  4. On the Device Security Password screen, type an incorrect password, and then click OK. Perform this step ten times to delete all data and applications.
Oct 29, 2009 | RIM BlackBerry 7290
What can i do for app error 523
Here is the resolution for your problem
Reload the BlackBerry Device Software on the BlackBerry device
Procedure
1.Install the BlackBerry Device Software on your computer.
2.Open BlackBerry Desktop Manager.
3.Connect the BlackBerry device to the computer.
4.If prompted, type your BlackBerry device password and click OK.
5.Complete one of the following steps:
6.Click Next.
7.If prompted, type your BlackBerry device password and click Next. Note: When the Application Loader Wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation. The selected check boxes indicate applications that are already installed on the BlackBerry device.
8.Select the check box for the BlackBerry Device Software.
9.Click Next.
10.If the On the Device Backup screen appears, choose whether to automatically back up the BlackBerry device and click Next.
11.Click Finish to begin loading the BlackBerry Device Software.
12.Click Close when the software is finished loading.
I hope i was able to help you.
Oct 13, 2009 | RIM BlackBerry Pearl 8100
Phone has error code 507 with a square and a triangle, and a line running trough it
Cause:
This error message can have the following causes:
While using the Application Loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
All data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
The Power Management feature on the computer turns off the USB ports.
The BlackBerry smartphone is connected to a laptop computer using a docking station.
Resolution
The following are possible resolutions for this issue.
Cause 1
Resolution 1
Complete the following steps:
Verify that you have the BlackBerry Device Software installed on your computer. For instructions, see KB03295.
If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
Use the Application Loader tool to install the BlackBerry Device Software.
Cause 2
Resolution 2
Open BlackBerry® Desktop Manager and double-click the Application Loader icon.
Cause 3
Note: This resolution is for Windows® XP users only.
Resolution 3
On your computer, click Start > Settings > Control Panel.
In the Control Panel, double-click the System icon. The System Properties window opens.
Click the Hardware tab of the System Properties, and click Device Manager.
In the Device Manager, double-click Universal Serial Bus Controllers.
Right-click the first USB root hub, and click Properties.
In the Properties window, click the Power Management tab.
Clear the Allow the computer to turn off this device to save power check box.
Repeat steps 5 to 7 for all other USB root hubs.
Restart your computer.
Cause 4
Resolution 4
Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
Re-install the BlackBerry Device Software using the Application Loader tool.
May 17, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
507 error resolution
The error message indicates that no applications are loaded on the BlackBerry smartphone.
Cause 1
While using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
  1. Verify that you have the BlackBerry Device Software installed on your computer. Before you use Application Loader to install software on your BlackBerry wireless device, verify that the necessary device software is installed on your personal computer.
    To verify what device software is installed on your computer
    1. In Desktop Manager, click Help>About Desktop Manager.
    2. Click the Device Software tab.
    The Device Software tab lists the device system software installed on your computer. If the tab is blank, then no device software exists.
  2. If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
  4. If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
  5. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  6. Use the application loader tool to install the BlackBerry Device Software.
Cause 2
  1. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  2. Use the application loader tool to install the BlackBerry Device Software.
Even after performing these steps if you could find the same error, please let us know so that we can provide the further resolution.
Mar 07, 2009 | RIM BlackBerry 7290 Smartphone
Reload software 507
Cause:
Resolution
Cause 1
Resolution 1
Cause 2
Resolution 2
Cause 3
Resolution 3
Cause 4
Resolution 4
Feb 18, 2009 | RIM BlackBerry Bold 9000 Smartphone
Agfa drystar 3000
Dear my Friends,
oftenly there are 03 cause for this reason:
firstly the problem can cause from the Power Supply. you should check for all the led on Power supply unit is light or not. if all of them is lighted please change to next step.
secondly, maybe the hard disk can not boot because the OS of this printer have problem you need to re-install the software for this printer. regularly this cause often is the main cause for this problem because this printer will not stable if the electric is went out while printing 95% for this case must be re- install the software . this is the reason while Agfa always warning you should use a UPS for this printer.
Notice: just only this type drystar3000 have this problem. others type is ds5300 ds5302 ds5500 ds5503 ,. drystar AXYS can solve this problem by itseft.
Thirdly, the cause can be from the Main MEC + THEMIS main boards (seldom happen with this reason)
please help me to re-check again,
do let me know if you have any question.
Regards.
email to : baoagfa@vnn.vn or quocbao.vo@agfa.com
Vo Quoc Bao - Service engineer
Agfa Representative Office in Vietnam.
91 Nguyen Trong Tuyen Str, Ward 15, PhuNhuan Dist-hcmc-vietnam
Dec 03, 2008 | Office Equipment & Supplies
Sony VO 9800 Chroma Output
There is a converter called the YCP-688 that did exactly this-- converted the Y/C 688 signal coming out of the Umatic deck to a Y/C 358 signal that any modern device with a s-video port (VCR, edit deck, capture card) could accept.
The company went out of business in 2007 , don't know if they are still for sale-- here's a link to it-
http://www.smithav.com/ycplus/docs/688.pdf
Nov 17, 2008 | Sony VO-9800 VCR
SONY VO-9800P U-Matis SP compatibility
No, this U-Matic VO-9800p ist a PAL Model, it only Records in SP and High Band Mode. If a SP Tape is inserted, it Records SPMode, otherwise High Band. Low Band Mode is only for Playback !
(Low Band Playback is of very poor Quality, do not use this for Digital DVD Captureing )
Oct 19, 2007 | Sony VO-9800 VCR
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
