Question about The Office Equipment & Supplies
What is the ribbon that sedco forms pro 50 using
3 Suggested Answers
jonsnell4
  • 26755 Answers
SOURCE: I need software for sedco formspro 50 win10
If available, it will be on the manufacturers web site.
Posted on Oct 28, 2017
jonsnell4
  • 26755 Answers
SOURCE: sedco formspro 50
Car or truck?
Oct 28, 2017 | Computers & Internet
Sedco formspro 50
Car or truck?
Oct 28, 2017 | Cars & Trucks
No lights on the top panel of Treadmill Pro-Form 345s
1) replace the old batteries by new ones. clean the contacts batteries very well
2) tight the ribbon cable for keypads and clean it
3) tight the upper connector vs lower connector
4) adjust the REED switch, see the diagram clean it, test for open or faulty and tight the connector.
Jan 22, 2013 | Proform Exercise & Fitness
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
Ribbon doesn't come up for the print wheel to hit it
First try a milti part form if it prints on the copy it's a ribbon, if not you probably have a broken print solenoid cap. If bthe ribbon isn't lifting sprat some WD40 on the ribbon motor. If this is an older machine there there is a large black gear on the R. side of the printer wiggle it it should move freely they do get tooth for tooth and not lift. We vsell print solenoid caps for 20.00 includes shipping and instructions.
DickyO
Jan 24, 2011 | Lexmark Wheelwriter 50 Series II...
On my 50 inch pioneer plasma I have a faded section thoughout the middle of the tv . about 4 " on each side does not have this ?
This can have multiple types of solutions for your problem that you are experiencing. It can either be your Logic Board (T-Con board) going bad, or it possibly be some parts going bad on the power supply board. In some cases I have found out that it was the ribbons connected to the actual plasma screen that are not connected tight enough, so when you apply some pressure to the outer ribbons ( you may have to try each ribbon to see if any of them fix the problem) usually I use a thick card like baseball card to apply pressure on the ribbon pushing it downwards. In most cases it will be either the upper left ribbon or right, again trying each one is your best bet if you are planning on diagnosing the problem yourself. If it does end up being the ribbon then that indicates the screen is going bad. Hope this helps
Jan 11, 2011 | Pioneer PureVision Pro-1000HD 50 in....
Dot matrix printer. very light print on last page of form
Hi and welcome to FixYa,
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Lexmark 2381 Plus Matrix Printer
PRINTER WON'T PRINT WITH COMPATIBLE RIBBON
You need to go to setup and scroll to options menu, there you'll find :"Ribbon check" , turn it off and your good to go!
Nov 10, 2008 | Printek FormsMaster 8003 Matrix Printer
Fargo pro-l using too much ribbon
It sounds like you may need to calibrate the ribbon sensor.
Go to the driver icon in your printers folder.
Right click on the Pro-L driver's icon, and select "Printing Preferences".
Click on the "Advanced" button in the lower right corner. A new window will open.
Scroll to the bottom and you will see "Calibrate...". Click on that and a button appears next to it that says "Properties...". Click the "Properites" button and another window appears.
On this screen, you'll see a button on the right side that says "Sensors...". Click on it, and yet another window opens. Almost there.
Here, you'll see two sections. The top section is for calibrating the ribbon sensor, the bottom is for the lamination sensor. Remove the ribbon and close the lid. Click on the "Send" button in the top section to calibrate the ribbon sensor. Your printer should beep twice.
After that, hit cancel on the previous windows to close out everything.
Normally this fixes this kind of problem, but if it doesn't, then there is something broke in the printer, possibly the sensor itself.
Dec 13, 2007 | Fargo Pro L ID Thermal Printer
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
