Question about Pro Office Equipment & Supplies
WHAT RIBBON USES SEDCO FORMS PRO 50 PRINTER - Pro Office Equipment & Supplies
4 Suggested Answers
  • 3 Answers
SOURCE: fargo pro-l using too much ribbon
It sounds like you may need to calibrate the ribbon sensor.
Go to the driver icon in your printers folder.
Right click on the Pro-L driver's icon, and select "Printing Preferences".
Click on the "Advanced" button in the lower right corner. A new window will open.
Scroll to the bottom and you will see "Calibrate...". Click on that and a button appears next to it that says "Properties...". Click the "Properites" button and another window appears.
On this screen, you'll see a button on the right side that says "Sensors...". Click on it, and yet another window opens. Almost there.
Here, you'll see two sections. The top section is for calibrating the ribbon sensor, the bottom is for the lamination sensor. Remove the ribbon and close the lid. Click on the "Send" button in the top section to calibrate the ribbon sensor. Your printer should beep twice.
After that, hit cancel on the previous windows to close out everything.
Normally this fixes this kind of problem, but if it doesn't, then there is something broke in the printer, possibly the sensor itself.
Posted on Mar 27, 2008
freetek
  • 5568 Answers
SOURCE: printer prints too light and not threw all copies of form
It's been a while, but I remember that that model has a print pressure setting on it; check your manual for the location on your model.
You should be able to print a 3-part form again.
Also, with the gradual demise of dot matrix, I suspect the available ribbons might already be somewhat dried out when purchased.
You can experiment as follows with an old cartridge that simply has a dried out ribbon that is not too badly wrinkled:
Carefully pry open the housing of the cartridge; they are not normally glued.
You will see the ribbon standing on edge, randomly snaking through the housing, and a round wheel that looks like a dense sponge; that's because it is.
Over a sink, spray WD-40 from a distance over the ribbon and then closer up, the wheel itself - DON"T overdo it! It will make blotchy print if you do.
Close the case again.
I have had the best results when using a drill motor attached to the provided finger nub that sticks up from the top to circulate (slowly!) the ribbon a few times; this will distribute the softened ink over all of the cartridge's ribbon.
I'm not that tight but have bought dried-out ribbons and live too far from the city to just run back to stuff it in their faces.
Posted on Jun 23, 2008
macminiguy
  • 34 Answers
SOURCE: PRINTER WON'T PRINT WITH COMPATIBLE RIBBON
You need to go to setup and scroll to options menu, there you'll find :"Ribbon check" , turn it off and your good to go!
Posted on Mar 03, 2009
Ribbon doesn't come up for the print wheel to hit it
First try a milti part form if it prints on the copy it's a ribbon, if not you probably have a broken print solenoid cap. If bthe ribbon isn't lifting sprat some WD40 on the ribbon motor. If this is an older machine there there is a large black gear on the R. side of the printer wiggle it it should move freely they do get tooth for tooth and not lift. We vsell print solenoid caps for 20.00 includes shipping and instructions.
DickyO
Jan 24, 2011 | Lexmark Wheelwriter 50 Series II...
It printing but with black forms on paper
black form because of ribbon is touching to the paper for this solution is adjust head gap of the printer or put the leaver in 3+1 setting ...and try ....
replace the ribbon mask ..........
Dec 10, 2009 | Epson LQ-2090 Matrix Printer
How to replace a print head on a T2265 sprint pro
Tally Genicom T 2265 Printer print head. The following information regarding Print Head is taken from Website. Please go through carefully. Print heads are very sensitive from the type of ribbons you use. These textile tapes, used as consumable in dot matrix printers are made by special technologies. They are impregnated with ink and special oils, which lubricate the print head wires during printing. While print head works, the quantity of ink and lubricant in ribbon exhausts, and the quality of printed matter gradually declines. When this quantity goes down below certain limits the ribbon begins wear to threads. These fine textile fibers mix with cellulose filaments from the paper and form a dark gray dust. This is a sure sign that the ribbon is dangerously worn and must be changed with a new one. Otherwise you will soon need a print head repair service. Still not satisfied about those points, please get in touch with local authorized printer service engineer to set right the issue. Have a Nice Day The same problems you may have with "old" ribbons, because after time the lubricants and inks get dry. The usage of "worn" or "dry" ribbon leads to difficult movement of the printhead's wires, its quick wear or crush. If you wish to use your printhead for a long time without any problems, you must use a quality ribbons with an original guarantee. Never use re-inked old ribbons. This surely guides you to print head repair or to buy a new one. It is a good idea to read the User's Guide for your printer, if you have not already done so. If you don't succeed in finding it, then carefully look at your printer and try to find the lever for printhead positioning, it controls the printhead gap. You must adjust manually this gap in correspondence with the number of printed copies.
Jul 15, 2009 | Office Equipment & Supplies
Dot matrix printer. very light print on last page of form
Hi and welcome to FixYa,
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Lexmark 2381 Plus Matrix Printer
I have a 7 year old Lexmark 2381plus dot matrix printer. Recently, the print on the last page of the 3 part form has become very hard to read (very light). I changed the ribbon and have the form setting...
It would seem you posted twice.
Nov 10, 2008 | Printek FormsMaster 8003 Matrix Printer
Problem while printing black on the black side
check the printer driver and see if YMCKK is selected in the driver.
Aug 07, 2008 | Fargo Pro L ID Thermal Printer
Printer prints too light and not threw all copies of form
If you lift the lid open do you see a lever to adjust the printer head closer to the paper?
Jun 23, 2008 | Panasonic KX-P2023 Matrix Printer
Datamax I-CLASS DMX-I-4212
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
Jun 03, 2008 | Datamax DMX-I-4212 Label Printer
Fargo pro-l using too much ribbon
Dec 13, 2007 | Fargo Pro L ID Thermal Printer
24 people viewed this question
Top Pro Office Equipment & Supplies Experts
k24674
Are you a Pro Office Equipment and Supply Expert? Answer questions, earn points and help others
