Question about GoVideo Go Video DVD/VCR Combo
GoVideo / just got cable box-cant display chanels
I have had my govideo for over a year and had it hooked up to basic cable with no problems recording w/timer and setting chanels. I just had a cable box installed, now with the govideo on chanel 3 all that displays is the channel that I am on with the cable remote,I cannot set the channel on the timer to record another station and using the video remote the other channels wont display.
Re: GoVideo / just got cable box-cant display chanels - GoVideo Go Video DVD/VCR Combo DVD & Blu-Ray Players
Posted on Mar 29, 2008
0 characters
3 Points
Timer recording will only record channel 3
Hello there,
This is most likely because the recorder is connected to a cable box. When setting the timer recording feature with a cable box as the source, you are not actually selecting the channel to record. You are selecting the recording source. The cable box sends all of the channels to the recorder using RF channel 3. In this case, the channel for recording will be whichever channel is selected on the cable box.
To help me give you a more definite answer, please can you answer the following quick questions:
1. Are you using a cable box?
2. If using a cable box, how is it connected to the recorder?
3. What is the model number of the GoVideo recorder, e.g. DVR4000?
Feb 18, 2011 | GoVideo Go Video DVD/VCR Combo
I have a govideo dvd recorder model #r6740 and
Straiten a paper clip, find small hole in front of cd face. Push paper clip in, It should release the tray.
Dec 29, 2009 | GoVideo R6740 DVD Recorder
Can not record channel 160? GoVideo only goes up to channel 125??
all machines go only to channel 125 maybe you have channel 160 on cable box or sky just set vcr to channel 3 or 4 and channel 160 will come thru vcr to your tv
Dec 16, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
How record tv chanels using the DTV converter box? The converter box determines the chanel of interes while the DVD recorder must remain on chanel 3 in my area. My DVD recorder is a combo with a VCR...
Can you connect directly from the DTV converter to the DVD recorder input using RCA phono connector cables? You'll have to select the input on the recorder menu as well.
Oct 21, 2009 | GoVideo Go Video DVD/VCR Combo
Digital converter box
You need to select channel 3 or 4 on your VCR! , or line-in if you connected through the (yellow/ white/ red) cable "better video quiality!" and selct the channel you want to record on your DTV box, not the VCR!
Sep 13, 2008 | GoVideo DV2150 DVD Player/VCR
Recording on GoVideo 2940
I am having the same problem. Did anyone get you an answer.
May 27, 2008 | GoVideo DVD Recorder/VCR with YesDVD
Govideo r6750 stuck tray
my 10 year old nephew forgot to take a disc out and inserted another this stopped the tray from opening i had to undo the screws holding the cover and remove them .Good luck p.s. don't forget to unplug firse
May 21, 2008 | GoVideo VR3845 DVD Recorder/VCR
Using Cable Box
two cords audio/out audio/in
vide/out from the cable box to the recorder video/in
Jan 24, 2008 | GoVideo R6640 DVD Recorder
No picture
might have to use it thought your vcr cable and tune it thought your tv
Jan 14, 2008 | GoVideo VR3845 DVD Recorder/VCR
Timer recording on GoVideo VR2940
First, you need to have the cable directly input into the recorder.
If you only plug the cable box into the machine, you get what is happening now.
After splitting the cable, one side into te box and the other into the recorder, run the channel seek part of the program and it will scan all the channels available on the cable and place them in memory.
Then plug the output of the cable box into the other input on the recorder, and you get yor pay channels and upper tiers.
Your recorder is now a switching unit as well
Nov 19, 2007 | GoVideo VR2940 DVD Recorder/VCR
GoVideo Go Video DVD/VCR Combo Logo
Top GoVideo DVD & Blu-Ray Players Experts
Jaime Hernandez
Are you a GoVideo DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
