Question about Tablets & eReaders
Stuck in reboot loop on Craig 8.5 inch HD Tablet Windows 10. Followed all procedures. Won't resolve.
TechyDrood
  • 2072 Answers
SOURCE: How to hard reset Craig 7 inch touchscreen tablet
Most tablets can be hard reset by pressing and holding the power button down for 10-15 seconds. Give that a try.
Posted on Dec 04, 2012
lion_hart44
  • 16 Answers
SOURCE: I received a gift the I craig 9 inch touch screen
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
Posted on May 21, 2014
Fame_Guru
  • 483 Answers
SOURCE: I have a Craig 7 inch touch screen tablet it comes
Dear Craig User,
I understand your delima with this tab, however unfortunately this product doesn't carry a very good market reputation.
For the kind of issue you are facing, I would recommend a reset (Hard reset) for which you may follow the following procedure.
Make sure the tablet is OFF.
Press and hold the Volume Up and Power buttons at the same time.
When the Android starts to flash, release the buttons.
Then try to press different hardware buttons until you are given a list of options.
Note: If Volume Up and Power doesn't work, try Volume Down and Power.
Post your update, let us know if it helped.
Regards,
Sid
Posted on Nov 12, 2014
  • 291 Answers
SOURCE: what dose code 10 mean for my proscan 7 inch tablet
It means you will likely have to do a "factory reset." That would return the tablet to "fresh out of the box" status. Yes, you lose what ever has happened since then.
1. Look for the reset hole on the sides of the device. 2. Poke the hole for 5 sec. using a paper clip or a pen. 3. The device will reset. If that did not worked try this. 1. Power off the device. 2. Press and Hold Volume down and Power button at the same time till you see the recovery screen. 3. Use volume down and select Wipe data/factory reset. 4. Press power button to accept. 5. Use Volume down and select YES. 6. Press power button to accept. 7. Press Power button to select Reboot after the reset.
Otherwise, you might have to take it to a shop or send it off and you won't like what that will cost if it is not under warranty.
Posted on Aug 26, 2015
  • 503 Answers
SOURCE: how do I get videos to loop on my nextbook ares 8 tablet?
some videos do not have loop options
it should be be with play settings
Posted on Nov 21, 2015
Can i buy a new screen for my icraig tablet cmp759
Replacement Touch Screen for iCraig Craig CMP756 Dual Core 9 ...
www.actablet.com/replacement-touch-screen-for-icraig-craig-cmp756-dual-core-9-in...
  1. Cached
  2. Similar
Digitizer Glass Capacitive Touch Screen Panel Replacement for iCraig Craig CMP756 Dual Core 9 Inch Android Tablet PC Features: Brand new, original touch ... Missing: cmp759
Amazon.com: Touch Screen/Panel Digitizer Glass Replacement Parts ...
https://www.amazon.com/Screen-Digitizer-Replacement...Tablet/dp/B00J09P2SM
  1. Cached
Buy Touch Screen/Panel Digitizer Glass Replacement Parts for CRAIG CMP738b 7" Tablet PC: Screens - Amazon.com ? FREE DELIVERY possible on eligible ... Missing: cmp759
LCD Display Screen Replacement for Craig CMP745e iCraig ...
https://www.amazon.com/Display-Screen-Replacement-Craig.../dp/B00LTB655S
  1. Cached
There are two layers of screen for a tablet. The one on the top is a touch screen, which works for the function of touch. The other below is the LCD screen, which ... Missing: cmp759
craig tablet cmp759 replacement screen - Buy Wholesale Phone ...
m.totobay.com/wholesaletags/craig-tablet-cmp759-replacement-screen/
  1. Cached
Items 1 - 20 of 5498 - craig tablet cmp759 replacement screen - Wholesale craig tablet ... Craig tablet 746e screen replacement icraig CMP759 screen panel ...
Craig Electronics Inc.
https://craigelectronics.net/
  1. Cached
Whether you are looking for audio products like our Bluetooth/WiFi Speakers, or portable products like our Action Cameras, and Tablets, we bring you the ... icraig tablet cmp759 Google Search
Feb 01, 2017 | Tablets & eReaders
My polaroid tablet will not boot
polaroid pmid701c tablet stuck at polaroid screen when rebooting ...
freaktab.com/.../tablet.../polaroid-tablets/835-polaroid-pmid701c-tablet-s...
Apr 14, 2012 - It just won't go past the Polaroid screen when booting. ... At this pointPolaroid has not released the factory ROM to be reflashed, supposedly sometime within the ... There are ROM's from Onda that does seem to work well. ROM ** Polaroid AS8 ** ROOTED + TWRP
Dec 24, 2013
Polaroid ptab7200 does not turn on
May 8, 2012
More results from freaktab.com
my polaroid tablet won't turn on - Tablets - Android Tablets - Tom ...
www.tomsguide.com/forum/id-2079971/polaroid-tablet-turn.html
Jun 20, 2015 - 6 posts - ‎5 authors
I have a Polaroid Tablet, Model PMID702C. ... Now, it will not power b. ... my tablet wont turn on , and when i charge it its not working how can i ... My Samsung tablet will not turn on. - Samsung
Dec 30, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
my tablet pc got boot loop - Tablets
Jul 28, 2014
Help! My tablet won't turn on! what do I do?! - Asus
Nov 5, 2013
More results from www.tomsguide.com
Jan 01, 2016 | Polaroid Tablets & eReaders
Just got a MID8042 want to watch from portable hard drive, will this work? t
Amazon.com : Coby Kyros 8-Inch Android 4.0 4 GB 4:3 ...
www.amazon.com/Coby-Kyros-8.../B0075W8Y1S
Amazon.com, Inc.Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 Capacitive .... The Coby Kyros MID8042-4 Tablet is a powerful and flexible internet and .... Simply connectyour Coby Tablet to your HD TV with an HDMI Cable is the ticket to .... I bought the Coby 8042 as a low cost portable device I could take with my while traveling.
Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 ...
www.amazon.com/Coby...Internet-Tablet/.../B0093XT...
Amazon.com, Inc.
Rating: 3.1 - ‎1,377 reviews
Amazon.com : Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 ... SANOXY® PU Leather Carrying Case For 8 inch Tablet Stand w/ USB ... With sleek and stylish Coby tablets, you can relax and enjoy your favorite music, 1080P HD videos, ..... Picksup home wi-fi & mobile hotspot (wi-fi from my phone) just great, never ...Missing: mid8042
Dec 29, 2015 | Coby kyros Tablets & eReaders
Is there a way I can fix my tablet it is stuck
try the reset hole. if that dont help then rebooting it may have to be the answer. but wen you reboot you will loose all photos .apps.ect
Nov 04, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
I have a tablet model number cmp743d my kids locked me out of my lock pattern and now it asks google name and password and I am locked out there too. Tried to reset with no luck. How can I fix it or do I...
1. Turn off your Craig CMP743d tablet by holding the Power button and selecting Power Off. 2. Simultaneously, hold the Back button and On button for 8 seconds. 3. When the android icon is seen already, press the Back button. 4. In the menu, just select the wipe/factory reset by pressing the Home button, followed by the pressing the Back button. 5. A new screen will appear. Select "Yes, delete all user data", then press Back button. 6. on the next screen, select "Reboot System Now" by pressing the Back button. 7. Just wait for your tablet to reboot.
Oct 08, 2014 | Tablets & eReaders
Tablet xhut off when on it
samsung galaxy 10 2.1 keeps rebooting and rebooting automatically. Displays going into power saving mode and reboots. stays on for aobut 10 seconds and then shuts down. Will not take a hard reboot. Help
Oct 29, 2013 | Samsung Galaxy 10 inch Tablet Wifi...
I have a craig touch screen tablet and i forgot my dot password how do i reset it?
Power the unit off (holding power buttom) and selecting Power off, then hold simultaneusly back button and on buttom 8 seconds,the android icon appear press back buttom, in the menu select wipe data/factory reset pressin home buttom and then press back buttom, in the next screen select "yes delete all user data" pressig back buttom, and in the nex screen select "reboot system now" with the back buttom and wait. IT WORK FOR MY TABLET
Aug 18, 2012 | Craig CMP741d Tablet
Tablets & eReaders Logo
87 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
