Question about Garden
M DAM TILLER LOPES AND DYES RUN ON CHOKE - Garden
    Top Expert:
  • Garden Master
  • 50,533 Answers
Clean out the main jet
put a 1/2 bottle of methylated spirits in the tank to remove any water in the system
Posted on May 03, 2017
Mantis tiller
Stan, I would suggest checking the air filter is okay first. It sounds like its struggling for air intake.
Jul 08, 2014 | Mantis Garden
Will only run on full choke
you have a plugged jet inside the carb take it apart and clean them all
Jun 12, 2012 | Craftsman 8.50 Torque Rating Rear Tine...
My tiller will only idle with the choke on once I open the choke it dies out. I just replaced the diaphrams and gaskits but it won't idle without the choke. I attempted to adjust the mixture screws but...
If it has been sitting for a while empty fuel tank. Prepare fresh fuel/oil mixture to fuel tank. Add two ounces of 100% acetone (available at Walmart) and attempt to start several times. Let sit for several minutes. Repeat until it acts like it wants to start.
Then watch this video and do it:
http://www.alamia.us/mantis_parts_s/148.htm
Never let tiller sit with fuel for any prolonged period of time. Run it out of fuel before storing or sitting. Acteone will remove varnish from inside.
Oct 21, 2010 | Mantis Tiller
Two stroke engine won't run without choke. Whats the problem?
Sounds like it is running lean. Look for loose carb or manifold nuts which will cause it to **** air and run lean, hence it needs more gas which is what the choke does. brucewo
Jul 03, 2010 | Mantis 2-Cycle Tiller
Will run with full choke on but once i turn choke off it dies
The carb jets are clogged, it will have to be removed and soaked in carb cleaner. Sometimes that will not work either, and the carb will have to be replaced. Reason is, some of the carb passages are as fine as a human hair, so it's hard to get gunk and bad/dried gas deposits out.
You could try running something called Sea Foam (mixed in the gas)from Walmart through the tiller for a while, that MAY help somewhat.
May 23, 2010 | Mantis 2-Cycle Tiller
Eu2000i lopes while idling. If i slide the choke
Also not uncommon to see a plugged idle circuit, cant remember how difficult it was to get to, but it's the smallest orifice in the carb, plugs the easiest, and these are real touchy on fuel, keep it fresh!
Apr 02, 2010 | Electrical Supplies
Troy bilt tiller
either the carb needs cleaned or theres a vacuum leak
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Cannot keep tiller running
Could a gas/oil mix been used by mistake. When you cleaned carb did you also clean dusty air filter?? Try leaveing off filter first and run. Are you sure you are in "choke position" when engines seems to be running ok,be sure to double check yourself here. If engine runs ecelleant in "choke" sounds like your in "Run" position and positioning is problem not performance.
Please rate. Thanks jj505
Mar 28, 2009 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
