Question about Kitchen Ranges
Wedgewood 60's model propane stove ,oven pilot is lit but no oven
Oven wont ignite?
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
SOURCE: gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Posted on Dec 14, 2008
Bat1956
  • 585 Answers
SOURCE: I have an older model brown stove and cannot light the oven pilot
The oven pilot is accessible through the broiler door, (you're pretty much laying on the floor to light it) or through the oven bu removing the oven bottom panel. To remove the oven bottom, place fingers in holes near the door, and apply pressure to slide the bottom toward the rear, and lift when the front (by your fingers) comes free. Remove completely and set aside. You should now see a flame spreader (V-shaped metal pan) retained by one or two winged screws. Removing the screws allows removal of the spreader. This exposes the burner, complete with pilot. There is two tubing lines to the pilot assembly, one about 1/4 inch dia. and one much smaller. the one at the end of the 1/4 inch tube is the pilot. The piece at the end of the really thin tube is the thermocouple. You have to heat the thermocouple to get the gas to come on to the pilot. A match just won't do it as you need to apply a flame to the thermocouple for about 30 seconds or so. Heat the thermocouple until the pilot will self-sustain. When the pilot stays on on it's own, put it all back together. If you elect to just go through the broiler, again heat the thermocouple until the pilot will self-sustian.
Posted on May 07, 2009
  • 3 Answers
SOURCE: I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Posted on Oct 16, 2009
SOURCE: Oven pilot light won't light
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
Posted on Feb 03, 2010
What are BTUs for vintage propane oven/cooktop?
This is the only thing I can find on that brand. I would have thought your propane supplier could have given you the information?
http://kellysfuel.com/at-the-cottage
Or you could Google propane stoves and pick one that is similar. I won't make that much difference. Like this site
https://propanerefrigerator.ca/Propane_Range.htm
T. Burners
Oven
Broil
Height
Height CSH
Width
Depth
Oven
Broiling
Weight
9000btu
14000btu
14000btu
40"
35"
20"
25.5"
14"h x 16"w x 19"d
13"w x 13"d
110lb
http://wedgewood-stove.com/pages/reprint.html
Antique Gas Stoves Owner Manuals for Antique Vintage Stoves
Apr 24, 2016 | Cooktops
I need to know how to light the oven? Does it have a pilot light like the stove top
most stoves do not have pilot lights but work from a pizo ignition system
when you turn on the gas knob ,the first action is to energize the pizo and that continually sparks to ignite the gas at the hob
the same is with the oven
ovens should be lit with the oven door open and once lit then the door can be closed
Jun 07, 2015 | Sears 61301 Gas Kitchen Range
Old wedgewood oven in home...very low pilot light in oven...how do I adjust it?
The oven pilot is usually located at the back of the oven; turn a screw on the pilot ignition unit to adjust the pilot flame height.
here is a link, pretty much all older ranges operate the same.
Gas Oven Pilot Lights Shutoff Valves and Ignition Systems HowStuffWorks
Feb 05, 2015 | Kitchen Ranges
Can't light oven in Wedgewood caravan oven
Do you have manual for proper lighting procedure? Do top burners have good flame?
Feb 27, 2013 | Atwood Mobile Products Atwood Wedgewood...
Our Wedgewood stove suddenly started acting up. We have to use the Reset button often to get any oven lighting at all. The pilots are fine. The broiler (separate compartment) is fine. But the oven lights...
It sounds like the problem is either the safety valve (the reset button) or the oven thermostat (the assembly behind the oven temperature knob). Both parts can be rebuilt (if they are original parts) and replacement parts are still made for 1940's and 50's Wedgewoods.
Mar 19, 2011 | Stoves Kitchen Ranges
Was preheating oven, while cooking on stove stop. heard a puff sound open up oven thought it was on but it never heated up. the electric light comes on but does not ignite. the broiler does the same. ...
Gas ovens are fitted with at least one safety device and it could be it has failed.
The safety device is bypassed while the pilot light is lit. The pilot light heats a thermocouple bulb which switches the gas on to the burner. As long as the pilot light continues to heat the bulb gas will continue to flow - until the thermocouple fails, they aren't long-lasting...
Feb 03, 2018 | Hotpoint 30" Self-Cleaning Freestanding...
I have a suburban propane oven in my RV. The stove works great but the oven after being on for 5 to 10 minutes starts to puf out. The flames dies then puffs back on. this happens over and over like it is...
My suburban oven pilot comes on but when I release the oven knob to turn on oven, pilot goes out and doesnt lite oven. I replaced safety valve but still the same problem.
Aug 31, 2009 | Ovens
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
GE STOVE MODEL JGBS15GE
Often times you will have problems with the gas thermostat and not necessarily with the safety valve. Once you have lit the pilot light, turn the oven knob to any temperature. The pilot light should get bigger in size of flame. If not, the thermostat that controls the oven must be replaced. If the pilot light does get bigger, but the stove does not ignite, it is the safety valve.
Nov 12, 2007 | GE JGBS07PEAWW Gas Kitchen Range
Kitchen Ranges Logo
687 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
