Question about Cell Phones
I have an Iphone 3, rings but when I go to answer I can hear them but they cannot hear me.
The ringer doesn't work
My iPhone Won't Ring! Here's The Real Reason Why.
www.payetteforward.com > Tech Blog > iPhone
Jul 19, 2014 - When the phone rings, you're going to hear it. ... Most of the time, the reason an iPhone doesn't ring for incoming calls is that the user .... when i checked back, my sound didnt work. do i need to go to the apple store? thanks.
Things to check if your phone doesn't ring when people call
www.centurylink.com/help/index.php?assetid=220
CenturyLinkThings to check if your phone doesn't ring when people call. Your friends and family tell you they try to call and either it just rings and rings or maybe they hear a ...
Volume buttons or ringer not working - iPhone 4 - iFixit
https://www.ifixit.com/.../Volume+buttons+or+ringer+not+working
iFixitSo for two weeks now my side volume buttons don't work. When I try to change .....However, the phone doesn't ring when someone calls or texts. The speakers ...
Why doesn't my landline ring? - phone telephone bt ' Ask MetaFilter
ask.metafilter.com/190429/Why-doesnt-my-landline-ring
Jan 06, 2016 | Lands Phones
My iphone 3g does not ring, i can hear the ring if i have on ear phones or an ear piece. the signal seems to be okay. the settings seem to be correct.
Dear Dburnett412.
If you can't hear the ringer when there is an incoming call to your iPhone 3G, you may have overlooked whether or not the ring/silent switch is set to silence the ringer. The ring/silent switch is above the volume switch. If you can see orange on this switch, it's set to vibrate. Switch it to ring and you should be all good.
If this doesn't help, you may want to consider resetting the iPhone.
Jun 30, 2011 | Cell Phones
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
When i make a call to any person he can hear me but i cannot hear when his phone is ringing and also cannot hear him speak but he can hear me very well .pls what i do to restor thia problem . and the phone...
First of all,
1. Check on the side volume buttons if the volume is to the maximum
2. Try making calls to some other person
3. If the above solutions don't work for you. Restore the iPhone
If you want more assistance on how to restore the phone. Contact me :)
Mar 27, 2011 | Apple iPhone Smartphone
I am trying to turn my ringer on. I was trying to change the number of rings from 4 to 3 and got all messed up Robert
The AT&T 1717 can be set to 2, 4 or tollsaver rings. Tollsaver means it will answer in 4 rings if their are no new messages and will answer in 2 rings when their is a new message. This is a convenience when checking for new messages when away from home or office. Cannot be set to answer in 3 rings. Press and hold the SETUP button until you hear the ring option announced, press ANNC/SKIP button or MEMO/REPEAT button until the ring option you want is announced. Press PLAY/STOP button to exit.
Jan 21, 2011 | AT&T 1717 Digital Answering Machine
My phone rings and when I answer it they can't hear me and I can't hear them
two things.
1. try taking your headphones and plugging them in, make and call and then unplug the headset while your still on the call.
2. This can also be caused by a manufacturers defect.
You can also plug into itunes and do a restore, if it is a problem with setting than this will reset the phone to factory default
Apr 14, 2010 | Apple iPhone Smartphone
How to change the numbr or rings before...
1) With the phone in standby mode, press the menu/clock key three times.
You hear “Ring time” and the current ring time ([2 ], [ 4], [6 ], [T ] Toll
saver), and it is displayed on the main base. Then you hear the guidance for setting
the ring time.
2) Press the volume/select/ or up or down arrow key until the desired ring time appears.
3) Press the set key to select the new ring time. You hear a confirmation tone, then
the announcement “Ring time” followed by the new ring time. After a few
seconds, the system announces “To set record time, press menu again.”
Need the manual for your phone? You can download/print it here:
http://www.uniden.com/pdf/DXAI5588-2om.pdf
Bill B
Mar 04, 2010 | Uniden DXA15588-2 Twin Cordless Phone
My iphone 1.1.3 doesn't work
press power button and home button together. press them 2gether for 10 secs. this is soft reboot.
this shud reboot the iphone.
u may need to put ur network settings again.
chao.
Jul 24, 2008 | Apple iPhone Smartphone
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
