Question about Homelite Garden
Homelite petrol pressure washer - Homelite Garden
2 Suggested Answers
  • 1498 Answers
SOURCE: Hi, We have a Homelite HPW-2200 Petrol Pressure
Hi Ann,
I'm Mike. Thanks or using Fixya.
Unfortunately we are strictly a support site, advising on repairs, functionality and references to a vast array of products.
While an increasing number of manufacturers have begun to refer their customers directly to us for remote support, there is no affiliation with any of them. nor the infrastructure to handle inventory billing, ordering or shipping.
Spare and replacement parts must still be acquired from the manufacturer.
Sorry for the inconvenience.
Posted on Aug 16, 2010
Why detergeant for homelite 2700 pressure washer only works with blue tip?
The chem venturi relys on low pressure to function this is specifically the blue nozzles job, to create a low pressure for the venturi to work.
otherwise you will be wasting chemical the entire time you are using the cleaner.
Hope this helps:)
Jul 14, 2014 | Homelite For Excell - Pressure Washer Pump...
Why can't I get pressure
Bypass valve may be stuck open bypassing the pressure.
Jun 23, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Homelite ut80522d pressure washer motor reves up and down then dies
It's surging... your carburetor needs to be serviced. It's not giving the proper air fuel ratio to the engine...
Jul 26, 2013 | Homelite Gas Pressure Washer: 2700 psi 2.3...
Remove&replace gas tank on a homelite 2600 pressure washer mod# ut80522
if you are in the UK we have found these parts to be available from Ryobi but they dont often make the engines... identify the engine as this is who will make the fuel tank !
Jun 30, 2013 | Homelite Pressure Washer. 2600 psi 2.3 GPM...
I bought a Homelite Petrol Pressure Washer HPW2400 off ebay there was no manual for it but looked on line at the spec and it says you can put detergent in it but have not got a clue were to do that any...
It has a detergent tank that attaches in line. You may have to buy the attachment.
Let us know how you like our service,
Thank You,
Jul 22, 2011 | Homelite Garden
We just purchased a Homelite Pressure Washer. We put new gas and oil into it, and it will run for about 2 minutes and then shut off. Now we can not even get it to run. We really don't want the hassle of...
A couple of things to check.. some rather obvious.
Assuming you have followed all the directions.. removed the pump vent plug before first use.. have a hose attached.. pressed the trigger on the wand to make sure you have water flowing etc.
Check to make sure the fuel valve is turned to ON.. fully..
If you Over filled the gas tank.. remove some of the petrol.. it should not be filled to the top...
Hopefully you put the correct amount and right type of oil into the crankcase.. again do not overfill the crankcase..
The fuel on most Homelite pressure washers is regular unleaded gasoline. NO E85 fuel should be used. Certainly no premixed gasoline for two cycle engines.
Check Choke position.. to start place in Cold Start or ON.. once started let it run for about 5 or ten seconds.. move it back to RUN..
If you ran it too long with the choke on you probably fouled the spark plug..
Remove it and clean it carefully.. if it is wet.. and all black.. it's fouled.. let it dry out.. clean it up properly (careful to not change the gap) replace and try again.
Lastly if you live in a neighborhood.. there is almost always a fellow nearby that is good with smalle engines.. ask around.. these guys are always happy to fiddle with these motors.
Best of luck to you!
Apr 10, 2011 | Homelite Garden
Checked everything, all knobs in the right position but after pulling the cord many times it won't crank up, this is the first time I am trying to use it, it is a Homelite 2600
Hi, even though i am stating the obvious , please check that you have petrol/gas in it , the fuel tap is turned on and that there is oil in it ( it has a internal oil alert switch that stops the machine running if there is little or no oil in it and usually there shipped with no oil in them )and make sure the engine stop/run switch is set to run/on , if this fails then take it back to the shop and demand a refund/replacement .
Hope this helps , please rate accordingly
Aug 31, 2010 | Honda Pressure Washer PSI 3000
Can't get pressure from homelite hp3127s gas pressure washer after using only 1 season. can't find manual to find problem. is there a switch i'm missing?
No,it's probably a bad valve body or the pump itself broke. Homelite isn't the best quality machine.
Jul 14, 2009 | Garden
Garden Logo
32 people viewed this question
Top Homelite Garden Experts
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
