Question about Pioneer Car Audio & Video
My pioneer amp 760 gm-5100t is connected to a 15 inch Kicker Comp plays music but no Bass done the wiring done fuses if I put pressure on some it hits but bad sound
SOURCE: POWER
short in the system, or bad ground, or connections?
Posted on Oct 23, 2007
AUTOSOUNDINS
  • 232 Answers
SOURCE: sub woofers dont give clear sound on high volume
THE AMPS PERFORMCE IS DIRECTLY RELATED TO THE STATE OF THE BATTERY AND THE CONNECTION FROM THE AMP TO THE BATTERY, CONNECT THE AMP DIRECTLY TO THE BATTERY TO SEE IF THE SAME PROBLEM EXIST OUTSIDE THE CAR
Posted on Aug 28, 2008
  • 631 Answers
SOURCE: Pioneer GM-5100T Car Audio Amplifier IS THE SYSTEM CONTROL WIRE THE SAME AS REMOTE WIRE
System control is the same as the remote turn-on from the head unit.
Posted on Nov 05, 2008
wdmb08
  • 34 Answers
SOURCE: ive got no power to the amp trough the rem wire unless i connect.
You need a bigger amp and make sure its a two channel. Four and five channel amps are for mids and highs. If you want real bass get a two channel. If you dont want to buy a bigger amp, Go get a capacitor. It acts like a battery charge storage for when your sub needs to hit those real low notes. It takes a lot of power. Also if you get a capacitor your altinater that charges your battery will not have to work so hard keeping your battery charged, Thus not wearing out your altinater and not having to replace it so soon because it will happen.
Another quick fix is turning your gain down. I turn my gain up half way, maybe a little past half way. You might not get the bass hitting as hard but at least it wont shut off on you.
Posted on Nov 20, 2008
etirbynnor
  • 655 Answers
SOURCE: bass sounds muddy and volume is minimum.
Hello mercedesman4,
Your setup sounds great. I had to settle for Blaupunkt in my Mercedes.
It sounds like the culprit is your enclosure. It's possible that by tweaking the settings, you could improve the sound somewhat, but having been used to the sound of a sealed enclosure, maybe not. Sealed enclosures tend to produce tighter, more accurate bass and have a flatter frequency response curve. They are also generally the enclosure of choice when looking for a SQ (sound quality) oriented setup.
Ported enclosures will produce louder bass than sealed enclosures, and maybe that's why some audio guys push them. They also allow the speaker to operate more efficiently, so you need less amp power for a given volume. Higher tuning on a ported box will get louder, but at the expense of sound quality. Lower tuning will still get louder than a sealed box, and the sound quality will be better than a box tuned higher, but still not as good as sealed. That's what I meant about tweaking the settings. You may see some improvement by setting the crossover lower, decreasing bass boost, or by turning the subsonic filter on/off. I'm no audiophile, but personally I've never been able to stand the sound of a ported enclosure, however it was tuned. Sealed just sounds better.
Hope this helps.
Posted on Mar 30, 2009
Amp pioneer 760 watts keeps blowing both 30 amp fuses when volume is raised
remember this amp when bridged can only go down to a 4 ohm load so if your subs are putting a load to the amp that is anything below 4 ohm than your going to have issues. is used as a 2 channel each channel can to 2 ohm but when bridged 4 ohm and above.
Aug 12, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Lex...
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
I have a pioneer 760 2 channel amp bridged to a kicker comp vr woofer. Amp has 8 gauge power and ground 18 gauge speaker wire run to woofer wooofer has 4 inputs two - two + . mine is run amp + to woofer +...
Ok, without knowing if you have the 2 or 4 Ohm Dual Voice Coil (DVC) version of the subwoofer, I'm going to assume you have the dual 4 Ohm version. The reason why is because, assuming you have the Pioneer GM-5300T amp, that amp does not support an 8 Ohm load. If you wire it in parallel, that would give you a 2 Ohm load. Parallel will be solid red connected to red/white dot, then to amp +, and solid black to black/white dot to amp -. Without knowing more specifics on the amp, that should fix the problem. Let me know what you get.
Apr 30, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Hi i have 760w pioneer that i am selling but i dont think it works because the red light does not come on when the wires are connected..are they're special wires that should be used for it to be connected?...
IF THE WIRING WAS RIGHT, THOUGH THE WIRE SIZE HE USE TO CHECK WAS NOT PERFACT, IT SHOULD HAD COME ON FOR ATLIST AS TESTING RESULT, CHECK THE WIRING AGAIN, AND FUSE..HOPE IT WORKS
Oct 13, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
No bass coming out
u probably have to replace the rca inputs on the amp or resolder the short on them if u can
Aug 31, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
System Remote Control Wire.
Wal Mart generally has 4g wiring kits for ~$40. Some of the kits contain everything you'll need to install your amp (including RCA cables, fuses and fuse holders).
If you want to understand more about car audio installation, read through the following site:
bcae1.com
Read the following pages specifically:
Installation Primer
Wire
Fuses
Amplifiers
Head Unit
Dec 28, 2007 | Pioneer GM-5100T Car Audio Amplifier
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
