Question about Cell Phones
My mobile not charging ...it continuesly shows Your charger is over voltage pls disconnect the charge...can i change it charge soket/ pin to solve this prblm? Pls help
rhuzmarhuz
  • 167 Answers
SOURCE: nokia 1600 ,insert sim and not charging solution
Either your sim card is not seated correctly, the contacts are dirty, the sim card is dead, the copper contacts in the phone do not reach the sim card or the electronics in the phone are faulty. try to change a new battery' or maybe the sim card driver is unsoldered' or need to replace. here is the pics. skilled technician can do. a4f7f33.jpg
Posted on Jan 12, 2008
SOURCE: blacberry pearl niot charging
I have a new blackberry pearl, have had it two weeks and today it will not charge no matter which charger I use so I don't know what the deal is.
Posted on Jun 12, 2008
fowlercomp
  • 119 Answers
SOURCE: Dell c640 charging problems.
Instead of spending alot of time trying to do something that could potentially harm your laptop..why not just buy a power supply?
You can get one here Click here for about 16 dollars. That's a great deal they are usually about $60 and its a Dell brand not some off brand.
Good Luck
Posted on Jan 19, 2009
ashieshbk
  • 153 Answers
SOURCE: memory full
Hii
Bro i suppose u might hav cleared msgs from ur sim memory and not phone memory. Anyways if the problem still persists , then try getting ur cellphones software updated from Moto Service center, Its done for free if ur still un warranty.
regards
Posted on Sep 06, 2009
Testimonial: "helo bro. thnks fr u r sugestions.. but i hv cleared all inbox n ouybox frm sim n phone memory,, thn also same problm.. anyway thnks a lot... tacare.."
SOURCE: nokia 6275 charger not supported problem i had
nokia 6275 cdma charging nt suported pls give me solution
Posted on Apr 26, 2010
How can i fix my laptop not chaing
Wiggle the cord. Check to make sure the cord end is fully inserted into the power brick that is about half way up the cord.
Jun 09, 2014 | Toshiba Satellite L45t-a4230nr 14" Led...
My charger on Rascal 600 does not charge. After checking all the common reasons without any luck I remove the charger and could not measure any voltage output. My Dealer sezs the charger won't work without...
Most chargers are 3 pin. Plus and minus charging voltage to the
batteries and a third pin monitors the actual battery voltage, so
that the automatic charger can turn itself off once the batteries
are fully charged. As Brad has mentioned, the connection
from the charger has to be made for the charger to produce
a voltage at those pins. The best way to see if it is charging
is to remove the seat and measure across both batteries..
assuming it's a 24volt system like most. Charging voltage
can be as high as 28volts across the positive of one 12volt
battery (connected in series to the other 12v battery) and the
negative of the other battery. You can monitor the charging
voltage across the batteries with a digital volt meter.
Nov 04, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Samsung galaxy s2 error message charging paused voltage too high
Dear Please try it:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 02, 2012 | Cell Phones
The battery on my 5230 wont charge up even tho its on the charger overnight ,ive charged it externally ,that is connecting the pos and neg from the charge lead diectly to the battery pos and neg this way...
just use a ziner diod neg leg of ziner sold to positive of charging connector and positive of ziner to battery connector plus ur problem will be solved
u can find ziner diod in old mobile like 1100 , 3300, 3310, 6600 etc.
Jun 06, 2011 | Nokia 5230 Cell Phone
I have nokia 3310 mobile i connect the charger and then mobile say reconnect charger pls solve my problam...
Possible that the charger is deficient in voltage and so is not delivering the required current for the battery to charge. You need to use a multimeter to check the charger, connect and measure the voltage at the battery terminal on the phone. It can also be a weak battery or shorted battery they can also show the symptom of no charging.
Ideal to get another charger battery from a friend to confirm before you buy one.
Mar 30, 2011 | Nokia 3310 Cellular Phone
My nokia 6220 classic was ok when i was going to sleep but at Morning its not switching on and not taking charge. When i connect my phone with charger it is becoming little hot and showing no charging...
there must be some problem in battery charging.change the battery and charge it.this will mostly helpful to you.if same problem exist means.then check the charging pin in your charger and in mobile too.if so try to change the charging pin of your mobile.
Dec 27, 2010 | Cell Phones
My phone is not charging. when the charger is connected it shows the battery icon blinking as while on charging. but it is not charging & the battery was also OK .
First Option:
Secend Option:
Aug 11, 2010 | Motorola Mobility ROKR E6 Smartphone
TRY TO CHARGE UR PHONE BY SWITCH OFF IT IF ITS NUTS SOLVE THE PROBLEM THAN DONT GO FOR ANY OTHER CHARGER AND HIGH VOLTAGE IT CAN DAMAGE TO UR PHONE SHOW UR MOBILE ANY NEAR MOBILE REPAIRING SHOP
Jul 15, 2008 | Nokia 6630 Handheld
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
