Question about Pioneer Car Audio & Video
My pioneer amp 760 gm-5100t with a 15 inch Kicker Comp the sub plays music but no Bass what is wrong is p****** me off
SOURCE: POWER
short in the system, or bad ground, or connections?
Posted on Oct 23, 2007
AUTOSOUNDINS
  • 232 Answers
SOURCE: sub woofers dont give clear sound on high volume
THE AMPS PERFORMCE IS DIRECTLY RELATED TO THE STATE OF THE BATTERY AND THE CONNECTION FROM THE AMP TO THE BATTERY, CONNECT THE AMP DIRECTLY TO THE BATTERY TO SEE IF THE SAME PROBLEM EXIST OUTSIDE THE CAR
Posted on Aug 28, 2008
  • 79 Answers
SOURCE: Support Question about RMS
Actually the amp should be able to power both of your subs. You have a 2 channel 760 watts amp
380 x 2 = 760 watts. If you want to go with a more powerful amp I would go with a 2 channel 2400 wats amp 1200 per channel = 2400 watts total. Which the peak power of your subs if you go over 2400 you have the risk of blowing your subs easily.
Posted on Jan 22, 2009
etirbynnor
  • 655 Answers
SOURCE: I have a Pioneer GM-5300T amp wired to a 10 inch
Hello pburgfootbal,
You do not specify which Kicker sub you have or how it is wired to the amp. The GM-5300T is only stable to 4ohms in bridged mode and if your sub is a 4ohm DVC with the coils in parallel, it presents a 2ohm load. If the sub is 2ohm DVC with the coils in parallel, the load is only 1ohm. Either configuration would be too low of an impedance for the amp in bridged mode. I'd check the sub specifications and make sure that the wiring configuration properly matches it to the amp.
Hope this helps.
Posted on Aug 01, 2009
  • 102 Answers
SOURCE: how many watts are in the kicker comp zr600 amp? i
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
Posted on Feb 05, 2010
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Lex...
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
No bass coming out
u probably have to replace the rca inputs on the amp or resolder the short on them if u can
Aug 31, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
I have a Pioneer GM-5300T amp wired to a 10 inch kicker sub. The music plays throughout the speakers of my car but the sub goes in and out. I noticed that the amp's power light dims when the sub goes in...
Hello pburgfootbal,
Hope this helps.
Jul 31, 2009 | Pioneer GM-5300T Car Audio Amplifier
There is no sound coming from my 15's when my stereo is on
it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Hits intemittently
ive had problems kinda like this ... normaly its a crossed or reversed speaker wire check the positive and negitive wire into the speakers "they move sometimes when there is more air moving around the speaker"
second make sure you have the impedence correct "possitive to positive negitive to negitive'
hope this helps
Dec 21, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
