Question about Toro Garden
I have a toro timecutter 5000. when I start it everything is good until I move the handles to move then the motor shuts down. It does it when I move either handle or engage the blades.Thanks
3 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Posted on Feb 19, 2009
czaa
  • 4982 Answers
SOURCE: when I engage hydaulic handles to mow engine cuts off. Phyd.and motor oil good
Needs an ajust. Try it urself w motor off. Local library has servicemanuals
Posted on Jul 18, 2015
How to raise the deck of a Toro SS 5000 mower above the highest factroy setting
Hi Robert:
I'd start by looking at the mechanism with the engine off while someone else moved the height adjust lever from hi to lo several times.
There will be 2 or 3 linkages that connect the deck vertically to the height adjust mechanism. Shortening these linkages should raise the cut height. If you're lucky, there should be enough clearance to allow the linkages to be drilled so that you can simply move the mounting pins into the new holes.
Or, you could make shorter linkages.
Best of luck.
Sep 30, 2015 | Toro TimeCutter SS5000 50 in. 22HP Smart...
Time cutter hydro does not move but i can hear it whine
Did you check the could have air in the system, did you check the hydro oil level? In my experience with toro hydro systems is when i change the oil air gets in the system. At low rpm move control handles forward and reverse several times until air works itself out. if this doesn't work more than likely there could be internal pump problems.
Sep 02, 2013 | Toro Riding Lawn Mower. TimeCutter SS4235...
Timecutter 4235 pulls to the right
first check the air pressure in the tires make sure they are the same then move the linkage rods on the slower side to balance the speeds out if it doesn't balance out you might have a pump or drive motor failing each side has its own pump and drive motor assuming you already check the fluid level
Aug 11, 2012 | Toro Lawn Mower With Toro Power Tools
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
Aug 07, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Garden Logo
37 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
